查看“配套视频资料”的源代码
配套视频资料
ARM裸机1期加强版 视频文档下载地址:https://eyun.baidu.com/s/3b1UtLc-》005_ARM裸机1期加强版 适宜人群 1. 有计算机,C语言和数电基础的大学生 2. 想转嵌入式Linux的单片机工程师 3. 嵌入式Linux底层工程师 4. 嵌入式Linux软件工程师 =芯片手册= * [[File:12MHz_2MHz晶体.pdf]] * [[File:16c2550-440-100504.pdf]] * [[File:1N4148WS.pdf]] * [[File:4.3寸液晶屏手册_AT043TN24.pdf]] * [[File:74HC32.pdf]] * [[File:74LVC16245.pdf]] * [[File:Am29LV160DB.pdf]] * [[File:AP2406.pdf]] * [[File:AP3407.pdf]] * [[File:ARM Architecture Reference Manual.pdf]] * [[File:AT24cxx.pdf]] * [[File:AT88SC0808C.pdf]] * [[File:AT93C46.pdf]] * [[File:AT93C56A_AT93C66A.pdf]] * [[File:BAT54_SERIES_4.pdf]] * [[File:CPU三星S3C2440A芯片手册.pdf]] * [[File:DC-DC电感.pdf]] * [[File:DC005C(电源插座).pdf]] * [[File:DM9000A.pdf]] * [[File:DM9000AE.pdf]] * [[File:DM9000CEP.pdf]] * [[File:DTC114YE.pdf]] * [[File:EM63A165TS(SDRAM).pdf]] * [[File:Epson_时钟晶体MC146.pdf]] * [[File:EPSON时钟晶体.pdf]] * [[File:EZ1117_EZ1117A.pdf]] * [[File:HB414-IV01E.pdf]] * [[File:HR911105A.pdf]] * [[File:HR911105A变压器一体网络插座.pdf]] * [[File:HY57V561620C(L)T(P)(Rev.0.5).pdf]] * [[File:IMP811.pdf]] * [[File:IN4148W.pdf]] * [[File:JTAG插座10P.pdf]] * [[File:JZ2440_4.3寸LCD手册_AT043TN24.pdf]] * [[File:K4S561632E.pdf]] * [[File:K9F1G08U0B.pdf]] * [[File:K9F2G08U0A.pdf]] * [[File:K9F2G08U0C(NAND FLASH).pdf]] * [[File:K9F2G08U0M.pdf]] * [[File:LCD WXCAT35-TG3_001F_V1.2(60pin).pdf]] * [[File:LCD插座.pdf]] * [[File:LTC3406.pdf]] * [[File:M41T11.pdf]] * [[File:MBR0530T1.PDF]] * [[File:MC33465.pdf]] * [[File:MF-MSMF050(自恢复保险).pdf]] * [[File:microsd_TF卡座.pdf]] * [[File:microUSB插座.pdf]] * [[File:MP3202(液晶屏背光驱动).pdf]] * [[File:MX29LV160DBTI-70G(NOR FLASH).pdf]] * [[File:MX29LV800BBTC.pdf]] * [[File:PH-4AW(串口白色4脚插座).pdf]] * [[File:PL2303TA(USB转串口).pdf]] * [[File:S3C2440A_UserManual_Rev13.pdf]] * [[File:SDRAM.pdf]] * [[File:SGM2019电源芯片.pdf]] * [[File:SK-12D07(启动选择开关).pdf]] * [[File:SMAJ5.0A(瞬态抑制二极管).pdf]] * [[File:SP6203超低噪声LDO.pdf]] * [[File:SST39VF160x_SST39VF320x_SST39VF640x.pdf]] * [[File:TD-15EA(贴片按键).pdf]] * [[File:TF卡插座.pdf]] * [[File:TPS72101.pdf]] * [[File:UDA1341TS.pdf]] * [[File:UDA1341TS_4.pdf]] * [[File:um_s3c2410a_manual_r10.pdf]] * [[File:USB主机插座.pdf]] * [[File:WM8976G.pdf]] * [[File:XC9216A13CMR.pdf]] * [[File:ZT135G1.doc]] * [[File:ZT135G1摄像头模组.doc]] =原理图= * [[File:JZ2440_V3电路图.pdf]] * [[File:V3器件型号(背面).pdf]] * [[File:V3器件型号(正面).pdf]] * [[File:V3位号(背面).pdf]] * [[File:V3位号(正面).pdf]] * [[File:JZ2440_V2电路图.pdf]] * [[File:spi_jz2440.pdf]] * [[File:spi_lcd_flash.pdf]] * [[File:spi_mini2440.pdf]] * [[File:spi_tq2440.pdf]] * [[File:JZ2440_sensors.pdf]] * [[File:JZ2440_V3电路图.pdf]] * [[File:V3器件型号(背面).pdf]] * [[File:V3器件型号(正面).pdf]] * [[File:V3位号(背面).pdf]] * [[File:V3位号(正面).pdf]] * [[File:JZ2440_V2电路图.pdf]] * [[File:spi_jz2440.pdf]] * [[File:spi_lcd_flash.pdf]] * [[File:spi_mini2440.pdf]] * [[File:spi_tq2440.pdf]] * [[File:JZ2440_sensors.pdf]] 学习目标 掌握写汇编代码的能力,可以分析任意裸板包括 u-boot、内核里的相关汇编代码 掌握常用的硬件部件操作,比如 GPIO,UART,I2C,LCD,触摸屏; 可以写出这些硬件部件的裸板程序 深入理解 ARM 体系统架构,可以写出具备中断功能的裸板程序,对程序现场的保存、恢复有所了解,这些原理适用于任何架构 CPU,内核及应用程序 熟悉裸板程序的结构,给你一个 bootloader 就能分析它的初始化部分、内存使用情况、链接地址、重定位、程序的相对跳转/绝对跳转等 掌握 bootloader 启动内核的原理,能完全自己写出一个 bootloader、字符设备驱动
配套视频资料
