查看“Buildroot SystemConfiguration”的源代码
Buildroot系统配置
=系统配置= System configuration ---> Root FS skeleton (default target skeleton) ---> (mini437x) System hostname (Welcome to Mini437x) System banner Passwords encoding (md5) ---> Init system (systemV) ---> /dev management (Dynamic using devtmpfs + mdev) ---> (system/device_table.txt) Path to the permission tables [ ] support extended attributes in device tables [ ] Use symlinks to /usr for /bin, /sbin and /lib [*] Enable root login with password () Root password /bin/sh (bash) ---> [*] Run a getty (login prompt) after boot ---> [*] remount root filesystem read-write during boot (eth0) Network interface to configure through DHCP [*] Purge unwanted locales (C en_US) Locales to keep () Generate locale data [ ] Enable Native Language Support (NLS) -*- Install timezone info (default) timezone list (Etc/UTC) default local time () Path to the users tables (board/mini437x/rootfs-overlay) Root filesystem overlay directories (board/mini437x/post-build.sh) Custom scripts to run before creating filesystem images () Custom scripts to run inside the fakeroot environment (board/mini437x/post-image.sh) Custom scripts to run after creating filesystem images () Extra arguments passed to custom scripts ==配置dev管理方式== /dev management (Dynamic using devtmpfs + mdev) ---> *配置为动态使用devtmpfs + mdev ==配置登陆信息== (mini437x) System hostname *设置主机名,作用是,在一个局域网中,每台机器都有一个主机名,用于主机与主机之间的便于区分,就可以为每台机器设置主机名,以便于以容易记忆的方法来相互访问。 (Welcome to Mini437x) System banner *登陆界面前的欢迎信息! Passwords encoding (md5) ---> *密码的加密方式! [*] Enable root login with password * 是否启用root用户并用密码登陆? () Root password *设置root密码,这里设置的是空,大家可以根据自己需求设定! ==配置登陆串口== [*] Run a getty (login prompt) after boot ---> --- Run a getty (login prompt) after boot (ttyS0) TTY port Baudrate (keep kernel default) ---> (vt100) TERM environment variable () other options to pass to getty 1.<code>TTY port</code>指的是串口号,这个要与内核中的配置一致!<br> 2.<code>Baudrate (keep kernel default)</code>这个保持默认即可!<br> 3.<code>(vt100) TERM environment variable</code>终端环境变量,VT100是一个终端类型定义,VT100控制码是用来在终端扩展显示的代码。默认即可!<br> ==其它配置== (board/mini437x/rootfs-overlay) Root filesystem overlay directories *根文件系统目录覆盖,主要是添加一些自己的bin文件,库,以及一些配置文件,其中<code>board/mini437x/rootfs-overlay</code> 是根文件系统目录覆盖文件的所在位置 (board/mini437x/post-build.sh) Custom scripts to run before creating filesystem images *在创建文件系统映像之前运行的自定义脚本,拷贝一些必须要的文件到目录 ()Custom scripts to run inside the fakeroot environment * (board/mini437x/post-image.sh) Custom scripts to run after creating filesystem images *创建文件系统映像后运行的自定义脚本,主要是拷贝一些文件,并按照自己的分区格式进行分区格式化! =详细注释:供参考= System configuration:系统配置 Root FS skeleton: System hostname:填写JZ2440 System banner Passwords encoding Init system:系统初始化,选择 BusyBox /dev management:设备文件管理,选择Dynamic using devtmpfs + mdev,即使用mdev动态加载设备节点的方式 Path to the permission tables:设备节点的配置表设置,一定要选择system/device_table_dev.txt,否则后面在dev目录下将不会生成各种设备节点。当然我们也可以手动的配置该文件,添加必要的节点或删除不需要的节点。 support extended attributes in device tables Use symlinks to /usr for /bin, /sbin and /lib Enable root login with password Root password:进入linux控制台终端后的密码,为空则登录时不需要密码,默认登录用户名为root。为空。 /bin/sh (busybox' default shell) Run a getty (login prompt) after boot:保持默认,默认为选中。 TTY port:配置为 ttySAC3 Baudrate :波特率,配置为 115200 TERM environment variable:默认即可 other options to pass to getty:默认即可 remount root filesystem read-write during boot Network interface to configure through DHCP Purge unwanted locales Locales to keep Generate locale data Install timezone info Path to the users tables Root filesystem overlay directories: Custom scripts to run before creating filesystem images Custom scripts to run inside the fakeroot environment Custom scripts to run after creating filesystem images [[Category:rootfs]] [[Category:buildroot]]
Buildroot系统配置
