查看“Buildroot TargetOptions”的源代码
buildroot如何配置目标单板架构
=配置单板架构= Target options ---> 目标板的配置 Target Architecture:目标架构,这里选择 ARM(little endian),ARM小端模式 Target Binary Format:二进制格式,为 ELF Target Architecture Variant:架构变体为 arm920t,内核类型 Target ABI:应用程序二进制接口,为EABI Floating point strategy:浮点数的策略,选择为 Soft float ARM instruction set:arm 汇编指令集,选择 ARM ==cortex-A8配置== Target Architecture (ARM (little endian)) ---> Target Binary Format (ELF) ---> Target Architecture Variant (cortex-A8) ---> Target ABI (EABIhf) ---> Floating point strategy (VFPv3-D16) ---> ARM instruction set (ARM) ---> ==cortex-A9配置== Target Architecture (ARM (little endian)) ---> Target Binary Format (ELF) ---> Target Architecture Variant (cortex-A9) ---> [*] Enable NEON SIMD extension support [*] Enable VFP extension support Target ABI (EABIhf) ---> Floating point strategy (VFPv3-D16) ---> ARM instruction set (ARM) ---> =参考链接= * 浮点类型介绍 https://wiki.debian.org/ArmHardFloatPort/VfpComparison * 浮点类型介绍 https://embeddedartistry.com/blog/2017/10/9/r1q7pksku2q3gww9rpqef0dnskphtc [[Category:buildroot]]
buildroot如何配置目标单板架构
