查看“Buildroot Toolchain”的源代码
Buildroot工具链
=配置工具链= Toolchain type (External toolchain) ---> ( ) Buildroot toolchain ( ) External toolchain =外部交叉编译工具链配置= (X) External toolchain ==手动移植工具链== 参考文章 https://blog.csdn.net/zhou_chenz/article/details/52346134 ==自动下载配置== Toolchain type (External toolchain) ---> *** Toolchain External Options *** Toolchain (Custom toolchain) ---> Toolchain origin (Toolchain to be downloaded and installed) ---> (https://publishing-ap-linaro-org.s3.amazonaws.com/...) ($(ARCH)-linux-gnueabihf) Toolchain prefix External toolchain gcc version (5.x) ---> External toolchain kernel headers series (4.0.x) ---> External toolchain C library (glibc/eglibc) ---> [*] Toolchain has SSP support? [*] Toolchain has RPC support? [*] Toolchain has C++ support? () Extra toolchain libraries to be copied to target [ ] Copy gdb server to the Target *** Host GDB Options *** [ ] Build cross gdb for the host *** Toolchain Generic Options *** [ ] Copy gconv libraries [*] Enable MMU support () Target Optimizations () Target linker options [ ] Register toolchain within Eclipse Buildroot plug-in =自动构建工具链= (X) Buildroot toolchain Toolchain type (Buildroot toolchain) ---> *** Toolchain Buildroot Options *** (100ask) custom toolchain vendor name C library (glibc) ---> *** Kernel Header Options *** Kernel Headers (Same as kernel being built) ---> Custom kernel headers series (4.1.x) ---> glibc version (2.23) ---> *** Binutils Options *** Binutils Version (binutils 2.26.1) ---> () Additional binutils options *** GCC Options *** GCC compiler Version (gcc 5.x) ---> () Additional gcc options [*] Enable C++ support [ ] Enable Fortran support [ ] Enable compiler link-time-optimization support [ ] Enable compiler OpenMP support [ ] Enable graphite support *** Host GDB Options *** [ ] Build cross gdb for the host *** Toolchain Generic Options *** [ ] Copy gconv libraries [*] Enable MMU support () Target Optimizations () Target linker options [ ] Register toolchain within Eclipse Buildroot plug-in =详细注释= Toolchain:工具链选项 Toolchain type:Buildroot提供两种方式使用toolchain external toolthain:非Buildroot提供的交叉编译器 Buildroot toolchain:Buildroot本身编译生成的Buildroot toolchain,直接选择此项 custom toolchain vendor name:填上S3C2440 C library:C库选择,选择 glibc Kernel Headers:内核头文件,Linux 4.9.x kernel headers glibc version:glibc版本选择,2.24 Binutils Version:binutils版本:2.27 Additional binutils options:附加的 binutils 选择,不填即可 GCC compiler Version:GCC版本选择,gcc 6.x Additional gcc options:附件的GCC选项,不填写即可 Enable C++ support:使能C++支持,选上 Enable Fortran support:使能Fortran语言支持,不选 Enable compiler link-time-optimization support:是否支持LTO,不选,LTO是什么:http://blog.csdn.net/fickyou/article/details/52381776 Enable compiler OpenMP support:支持OpenMP?OpenMP用于共享内存并行系统的多处理器程序设计,OpenMP并不适合需要复杂的线程间同步和互斥的场合,OpenMp的另一个缺点是不能在非共享内存系统(如计算机集群)上使用。不选择 Enable graphite support :是否支持graphite。Graphite是应用WEB应用的一套开源的编程接口。不选择。具体看百度百科:https://baike.baidu.com/item/Graphite/9810474?fr=aladdin Build cross gdb for the host:主机上运行gdb进行调试,不选 Copy gconv libraries:拷贝 gconv库,gconv库用于在不同字符集之间进行转换。默认不选即可 Enable MMU support:使能 MMU,S3C2440支持MMU,选上 Target Optimizations:不选 Target linker options:不选 Register toolchain within Eclipse Buildroot plug-in:eclipse插件支持,不选 =参考网址= * Toolchain介绍 https://www.slideshare.net/anil_pugalia/toolchain-4566799 * linaro工具链下载地址 https://releases.linaro.org/components/toolchain/binaries/ [[Category:rootfs]] [[Category:buildroot]]
Buildroot工具链
