{| width="100%" background-color: rgba(255,255,255,0.2)" |- | 视频链接地址: || 开发板购买地址: |- | 资料光盘下载地址: ||配套视频wiki教程: |- | 裸机程序wiki || 驱动程序wiki |} =介绍= 100ask Am335x是 百问网基于美国TexasInstruments公司ARM Cortex-A8内核的高性能、低功耗微处理器,设计的工业级开发板! * http://processors.wiki.ti.com/index.php/Sitara_AM335x_Portal * http://www.ti.com/processors/sitara-arm/am335x-cortex-a8/overview.html * http://processors.wiki.ti.com/index.php/AM335x_Hardware_Design_Guide ==基本资源特征== ==接口布局和尺寸== {| class="wikitable" width="100%" style="text-align: center; background-color: rgba(255,255,255,0.2)" |- ! 开发板!! 扩展版 |- |[[File:100ask_am335x_002.png|1000px ]]|| [[File:100ask_am335x_003.jpg|248px]] |} ==硬件资源介绍== ==配套资料介绍== {| class="wikitable toccolours mw-collapsible mw-collapsed" style="text-align:left; width:auto; overflow:auto; " !colspan="3"|00_UserManual |- |rowspan="3"| 二级目录 |100ask_am335x初级用户手册.pdf |手册使用详解 |- |100ask_am335x硬件手册.pdf | |- |100ask_am335x初级用户手册.pdf | |} {| class="wikitable toccolours mw-collapsible mw-collapsed" style="text-align:left; width:auto; overflow:auto; " !colspan="3"|01_tools <-----------------包含用户手册 |- |rowspan="9"| 二级目录 |100ask-vmware_ubuntu18.04.7z |Windows下编译开发环境,主要适用模块应用开发 |- |FileZilla_3.22.1_win32-setup.exe |Windows下ftp工具,传输文件到Ubuntu系统中 |- |HP USB Disk Storage Format Tool 2.0.6.EXE | |- |MobaXterm_Portable_v11.0.zip | |- |npp.7.6.1.Installer.exe | |- |qt-creator-opensource-linux-x86_64-4.8.0.run | |- |SD Card Formatter 5.0.1 Setup.exe | |- |VMware-workstation-full-15.1.0-13591040.exe | |- |win32diskimager-1.0.0-install.exe | |} {| class="wikitable toccolours mw-collapsible mw-collapsed" style="text-align:left; width:auto; overflow:auto; " !colspan="4"|01_tools <-----------------包含用户手册 |- |rowspan="8"| 二级目录 |nandflash_system |- |rowspan="6" | 三级目录 |- |colspan="3" | MLO |- |colspan="3" | rootfs.ubi |- |colspan="3" | u-boot.img |- |colspan="3" | uEnv.txt |- |colspan="3" | zImage |- |colspan="3" |100ask-am335x.dtb |} =快速入门= ==准备工作== 要使用你的AM335x开发板,请提前准备好以下资源: * 一台可以上网的windows电脑 * 100ask AM3358开发板 * microSD卡/TF卡: Class10或以上的 8GB SDHC卡 * 一个12v/2A的电源是配置 * VMware-player-15.1.5.exe * Vmware ubuntu 18.04 64位虚拟机镜像 * win32diskimager-1.0.0-install.exe * HPUSBDiskStorage_Format_Tool 2.0.6.EXE * MobaXterm_Portable_v11.0.zip 如需自行安装配置vmware ubuntu开发环境请参考[[Configuring_ubuntu ]] =编译系统= ==获取源码== {| class="wikitable" width="100%" style="text-align: center; background-color: rgba(255,255,255,0.2)" |- ! 类别 !! 国内coding仓库 !! 国外github仓库 |- |u-boot|| https://dev.tencent.com/u/weidongshan/p/100ask-am335x_uboot || https://github.com/100askTeam/100ask-am335x_uboot |- |linux kernel|| https://dev.tencent.com/u/weidongshan/p/100ask-am335x_kernel|| https://github.com/100askTeam/100ask-am335x_kernel |- |根文件系统|| https://dev.tencent.com/u/weidongshan/p/100ask-am335x_buildroot|| https://github.com/100askTeam/100ask-am335x_buildroot |} git邮箱账号和用户名配置 git config --global user.email "you@example.com" git config --global user.name "Your Name" 初次使用,需要配置用户名和密码才可以进行代码同步,用户名和密码根据自己情况设定,也可以随意设定 考虑到代码仓库过多,特使用repo工具管理代码<br> repo工具配置 book@100ask:~$ git clone https://git.dev.tencent.com/codebug8/repo.git book@100ask:~$ mkdir -p 100ask_am335x && cd 100ask_am335x book@100ask:~/100ask_am335x$ ../repo/repo init -u https://dev.tencent.com/u/weidongshan/p/manifests/git -b linux-sdk -m ti335x/100ask-am335x_linux_release_v1.0.xml --no-repo-verify book@100ask:~/100ask_am335x$ ../repo/repo sync -j4 上面使用的repo管理为国内coding仓库 ==设置工具链== 交叉编译工具链主要是用于在ubuntu主机上编译并声称可以在其它平台上运行的系统。设置交叉编译工具主要是设置PATH, ARCH和CROSS_COMPILE三个环境变量,下面介绍具体设置方法。 * 永久生效 如需永久修改,请修改用户配置文件, Ubuntu系统下,修改如下: vim ~/.bashrc 在行尾添加或修改: export ARCH=arm export CROSS_COMPILE=arm-linux-gnueabihf export PATH=$PATH:<WORKDIR>/100ask_am335x/ToolChain/gcc-linaro-6.2.1-2016.11-x86_64_arm-linux-gnueabihf/bin * 临时生效 执行完“export”命令后,该设置只对当前终端有效 book@100ask$ export PATH=$PATH:<WORKDIR>/100ask_am335x/ToolChain/gcc-linaro-6.2.1-2016.11-x86_64_arm-linux-gnueabihf/bin book@100ask$ export ARCH=arm book@100ask$ export CROSS_COMPILE=arm-linux-gnueabihf- * 手动指定 Make编译时指定ARCH架构 CROSS_COMPILE交叉编译工具链 book@100ask$ make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- [命令] ==编译uboot== book@100ask$ cd u-boot book@100ask:u-boot$ make distclean book@100ask:u-boot$ make 100ask_am335x_defconfig book@100ask:u-boot$ make * uboot常用参数 ** nfs启动系统 setenv rootpath /work/rootfs_335x set ipaddr 10.10.10.23 setenv serverip 10.10.10.66 setenv fdtfile 100ask-am335x.dtb run netboot ==编译linux kernel== book@100ask$ cd linux-kernel book@100ask:linux-kernel$ make mrproper book@100ask:linux-kernel$ make 100ask_am335x_defconfig book@100ask:linux-kernel$ make zImage book@100ask:linux-kernel$ make dtbs 编译内核模块 book@100ask:linux-kernel$ make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- modules 安装内核模块到nfs根文件系统 book@100ask:linux-kernel$ sudo make ARCH=arm INSTALL_MOD_PATH=</media/rootfs> modules_install ==编译根文件系统== {| class="wikitable" width="100%" style="text-align: center; background-color: rgba(255,255,255,0.2)" |- ! 配置文件 !! 含义 |- | 100ask_am335x_qt_defconfig || 文件系统版本(再默认版本支持了qt) |- | 100ask_am335x_defconfig || 完整系统镜像版本(包含uboot kernel最后会生成所有的文件以及一个完整的系统镜像) |} book@100ask$ cd buildroot2018.02 book@100ask:buildroot2018.02$ make clean book@100ask:buildroot2018.02$ make 100ask_am335x_defconfig book@100ask:buildroot2018.02$ make menuconfig book@100ask:buildroot2018.02$ make –jN /*N表示CPU的线程数*/ 编译后生成文件介绍 <syntaxhighlight lang="c" > buildroot2018.02 ├── output ├── images ├── am335x-evm.dtb <--设备树文件 ├── boot.vfat <--分区文件 ├── MLO <--启动引导 ├── ramdisk.gz <--RAM格式根文件系统 ├── rootfs.cpio ├── rootfs.cpio.gz ├── rootfs.cpio.uboot ├── rootfs.ext2 <--ext2格式根文件系统 ├── rootfs.ext4 -> rootfs.ext2 ├── rootfs.tar <--打包后的根文件系统 ├── rootfs.tar.gz <--打包并压缩的根文件系统,适用于NFSROOT启动 ├── rootfs.ubi <--支持nandflash加载的根文件系统 ├── rootfs.ubifs ├── sdcard.img <--完整的SD卡系统镜像 ├── u-boot.bin <--qspi启动的u-boot ├── u-boot.img <--u-boot镜像 ├── u-boot-spl.bin <--spl启动镜像 ├── uEnv.txt <--默认u-boot配置文件 └── zImage <--内核镜像 </syntaxhighlight> ==sd卡启动== 1.安装资料光盘下01_tools/SD Card Formatter 5.0.1 Setup.exe软件,安装完成后打开!<br> 2.使用SdCardFormatter格式化SD卡,格式化步骤如下如所示! {| class="wikitable" width="100%" style="text-align: center; background-color: rgba(255,255,255,0.2)" |- | style="width: 33%;" | [[image:100ask_am335x_SD_P_004.png | 300px]] | style="width: 33%;" | [[image:100ask_am335x_SD_P_005.png | 300px]] | style="width: 33%;" | [[image:100ask_am335x_SD_P_006.png | 300px]] |- | (1)选择要格式化的SD卡,选中Quick format,点击Format || (2)在弹出的对话框中点击是(Y) || (3)等待格式化完成,在弹出的对话框中点击确定 |} 3.安装资料光盘下01_tools/ win32diskimager-1.0.0-install.exe软件,安装完成后打开!<br> 4.使用wind32diskimage烧写编译后的系统镜像,烧写步骤如下所示!<br> {| class="wikitable" width="100%" style="text-align: center; background-color: rgba(255,255,255,0.2)" |- | style="width: 33%;" | [[image:100ask_am335x_SD_p_001.png | 300px]] | style="width: 33%;" | [[image:100ask_am335x_SD_p_002.png | 300px]] | style="width: 33%;" | [[image:100ask_am335x_SD_p_003.png ]] |- | (1)选中需要烧写的SD卡设备,点击文件图标选择系统镜像文件,最后点击写入按钮开始烧写 || (2)此时弹出烧写对话框,点击Yes按钮,继续烧写, 等待任务进度执行到100%) || 烧写成功后,弹出写入成功,此时点击OK |} ==nandflash启动== 进入资料光盘01_tools目录,右键以管理员权限运行HP USB Disk Storage Format Tool 2.0.6.EXE程序,来格式化SD卡, 拷贝资料光盘目录下的nandflash_system下所有文件到格式化好的SD卡中。 把SD卡插到开发板上,并设置启动方式为mmc启动,打开终端,开发板上电,串口有输出时按下任意键即可进入uboot参数设置界面,如下所示 拷贝资料光盘目录下的nandflash_system下所有文件到格式化好的SD卡中。 把SD卡插到开发板上,并设置启动方式为mmc启动,打开终端,开发板上电,串口有输出时按下任意键即可进入uboot参数设置界面,如下所示 <syntaxhighlight lang="c" > CCCCCCCC U-Boot SPL 2016.05 (Apr 24 2019 - 13:18:09) PMIC detected:TPS65217 Trying to boot from MMC1 reading u-boot.img reading u-boot.img U-Boot 2016.05 (Apr 24 2019 - 13:18:09 +0800) CPU : AM335X-GP rev 2.1 Watchdog enabled I2C: ready DRAM: 512 MiB NAND: 512 MiB MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1 *** Warning - bad CRC, using default environment Net: cpsw Press SPACE to abort autoboot in 2 seconds 100ask# </syntaxhighlight > 此时输入<code> run updatesys </code> <syntaxhighlight lang="c" > NAND write: device 0 offset 0xc0000, size 0xa93e0 693216 bytes written: OK reading zImage 3461240 bytes read in 213 ms (15.5 MiB/s) type=8 HW ECC BCH8 Selected NAND write: device 0 offset 0x200000, size 0x34d078 3461240 bytes written: OK reading rootfs.ubi 67502080 bytes read in 4046 ms (15.9 MiB/s) SW ECC selected NAND write: device 0 offset 0xa00000, size 0x4060000 67502080 bytes written: OK </syntaxhighlight> 如上所示,直到系统打印<code>system update ok !</code> ,表示系统烧录nandlflash成功。 此时可以关闭开发板电源,拔出SD卡 设置启动方式为nand启动, 开发板重新上电即可! =更新日志= =反馈建议= [[Category:TexasInstruments]][[Category:am335x]]
