查看“Configuring ubuntu”的源代码
Ubuntu开发环境配置
=ubuntu16.04安装= ==ubuntu16.04-android环境配置== ==linux kernel环境配置== *基本依赖 <syntaxhighlight lang="Bash" > sudo apt-get install gcc make git vim python net-tools openssh-server \ python-dev build-essential subversion \ libncurses5-dev zlib1g-dev gawk gcc-multilib flex git-core gettext \ gfortran libssl-dev libpcre3-dev xlibmesa-glu-dev libglew1.5-dev \ libftgl-dev libmysqlclient-dev libfftw3-dev libcfitsio-dev graphviz-dev \ libavahi-compat-libdnssd-dev libldap2-dev libxml2-dev p7zip-full \ libkrb5-dev libgsl0-dev u-boot-tools -y </syntaxhighlight> ===编译android 5.1=== *安装java-jdk-1.7 <syntaxhighlight lang="Bash" > sudo add-apt-repository ppa:openjdk-r/ppa sudo apt-get update sudo apt-get install openjdk-7-jdk sudo update-java-alternatives -s java-1.7.0-openjdk-amd64 sudo java -version </syntaxhighlight > *安装编译android 5.1依赖环境 <syntaxhighlight lang="Bash" > sudo apt-get install -y git flex bison gperf build-essential libncurses5-dev:i386 libc6-dev-i386 \ libx11-dev:i386 libreadline6-dev:i386 libgl1-mesa-dev g++-multilib \ tofrodos python-markdown libxml2-utils xsltproc zlib1g-dev:i386 \ dpkg-dev libsdl1.2-dev libesd0-dev \ git-core gnupg flex bison gperf build-essential \ zip curl zlib1g-dev gcc-multilib g++-multilib \ lib32ncurses5-dev x11proto-core-dev libx11-dev \ lib32z-dev ccache squashfs-tools libncurses5-dev pngcrush schedtool libxml2\ libgl1-mesa-dev unzip m4 lzop libc6-dev lib32z1-dev \ libswitch-perl libssl1.0.0 libssl-dev </syntaxhighlight> =ubuntu18.04安装= ==linux kernel环境配置== *基本依赖 <syntaxhighlight lang="Bash" > sudo apt-get install gcc make git vim python net-tools openssh-server \ python-dev build-essential subversion \ libncurses5-dev zlib1g-dev gawk gcc-multilib flex git-core gettext \ gfortran libssl-dev libpcre3-dev xlibmesa-glu-dev libglew1.5-dev \ libftgl-dev libmysqlclient-dev libfftw3-dev libcfitsio-dev graphviz-dev \ libavahi-compat-libdnssd-dev libldap2-dev libxml2-dev p7zip-full \ libkrb5-dev libgsl0-dev u-boot-tools -y </syntaxhighlight> ==ubuntu18.04-android环境配置== ===编译android 7.1=== *安装java-jdk-1.8 <syntaxhighlight lang="Bash" > sudo apt-get install openjdk-8-jdk openjdk-8-jre sudo java -version </syntaxhighlight > *安装编译android 7.1依赖环境 <syntaxhighlight lang="Bash" > sudo apt-get install m4 g++-multilib gcc-multilib \ lib32ncurses5-dev lib32readline6-dev lib32z1-dev flex curl bison </syntaxhighlight> ===编译android 8.1=== *安装java-jdk-1.8 <syntaxhighlight lang="Bash" > sudo apt-get install openjdk-8-jdk openjdk-8-jre sudo java -version </syntaxhighlight > *安装编译android 7.1依赖环境 <syntaxhighlight lang="Bash" > sudo apt-get install libx11-dev:i386 libreadline6-dev:i386 libgl1-mesa-dev g++-multilib \ git flex bison gperf build-essential libncurses5-dev:i386 \ dpkg-dev libsdl1.2-dev libesd0-dev \ git-core gnupg flex bison gperf build-essential \ zip curl zlib1g-dev gcc-multilib g++-multilib \ libc6-dev-i386 lib32ncurses5-dev x11proto-core-dev libx11-dev \ libgl1-mesa-dev libxml2-utils xsltproc unzip m4 \ lib32z1-dev ccache make tofrodos \ python-markdown libxml2-utils xsltproc zlib1g-dev:i386 -y </syntaxhighlight> ==ftp配置== sudo apt install vsftpd 并修改 #write_enable=YES 为 write_enable=YES 编译 tiimage.c , 把tiimage放到/usr/bin 编译 rkimage.c, 把rkimage放到/usr/bin =环境配置= ==基本依赖安装== ==通过samba传输文件== ==通过sftp协议传输文件== ==使用vmware共享windows磁盘==
Ubuntu开发环境配置
