查看“Firefly-rk3288 build Android-5.1”的源代码
=编译firefly android-5.1系统= <div style="color:#F00; font-size: 1.1em">注意:此章节操作均在我们提供的资料光盘以及vmware ubuntu16.04进行过测试,确保其可用。</div> ==配置编译环境== *下载Android-5.1 SDK 使用浏览器打开 https://pan.baidu.com/s/14Zpf2-QSQYxhqM9OcxyuAQ 保存资料光盘中的 Firefly-sdk_v1 到自己的网盘中,让后进行下载。 *安装jdk7编译环境 <syntaxhighlight lang="Bash" > sudo add-apt-repository ppa:openjdk-r/ppa sudo apt-get update sudo apt-get install openjdk-7-jdk sudo update-java-alternatives -s java-1.7.0-openjdk-amd64 sudo java -version </syntaxhighlight> *安装基本依赖包 <syntaxhighlight lang="Bash" > sudo apt-get install -y git flex bison gperf build-essential libncurses5-dev:i386 libc6-dev-i386 \ libx11-dev:i386 libreadline6-dev:i386 libgl1-mesa-dev g++-multilib \ tofrodos python-markdown libxml2-utils xsltproc zlib1g-dev:i386 \ dpkg-dev libsdl1.2-dev libesd0-dev \ git-core gnupg flex bison gperf build-essential \ zip curl zlib1g-dev gcc-multilib g++-multilib \ lib32ncurses5-dev x11proto-core-dev libx11-dev \ lib32z-dev ccache squashfs-tools libncurses5-dev pngcrush schedtool libxml2 \ libgl1-mesa-dev unzip m4 lzop libc6-dev lib32z1-dev \ libswitch-perl libssl1.0.0 libssl-dev p7zip-full </syntaxhighlight> *使用<code>FileZilla</code>或其它软件上传下载后的 Android-5.1_sdk 源码包,让后通过7z工具进行解压 <syntaxhighlight lang="Bash" > 7z x firefly-rk3288_android5.1_git_20180126.7z.001 </syntaxhighlight> ==手动编译== 手动编译firefly-rk3288和firefly-rk3288-reload,编译内核时,所用的资源文件不同 ===编译uboot=== cd ~/proj/firefly-rk3288-lollipop/u-boot make rk3288_defconfig make -j8 ===内核编译使用Firefly-RK3288 编译内核:=== cd ~/proj/firefly-rk3288-lollipop/kernel make firefly_defconfig make -j8 firefly-rk3288.img ===编译Android=== cd ~/proj/firefly-rk3288-lollipop source build.sh lunch rk3288_box-userdebug make -j8 ./mkimage.sh ===打包成统一固件=== 编译完可以使用Firefly的脚本打包成统一固件,执行如下命令: ./FFTools/mkupdate/mkupdate.sh -l rk3288_box-userdebug 打包完成后固件所在目录及名称<code>rockdev/Image-rk3288_box/Firefly-RK3288_Android5.1.1_Public_190805.img</code> ==构建变体说明== *默认的目标构建变体(TARGET_BUILD_VARIANT)为 userdebug。常用变体有三种,分别是用户(user)、用户调试(userdebug)和工程模式(eng),其区别如下: user 仅安装标签为 user 的模块 设定属性 ro.secure=1,打开安全检查功能 设定属性 ro.debuggable=0,关闭应用调试功能 默认关闭 adb 功能 打开 Proguard 混淆器 打开 DEXPREOPT 预先编译优化 userdebug 安装标签为 user、debug 的模块 设定属性 ro.secure=1,打开安全检查功能 设定属性 ro.debuggable=1,启用应用调试功能 默认打开 adb 功能 打开 Proguard 混淆器 打开 DEXPREOPT 预先编译优化 eng 安装标签为 user、debug、eng 的模块 设定属性 ro.secure=0,关闭安全检查功能 设定属性 ro.debuggable=1,启用应用调试功能 设定属性 ro.kernel.android.checkjni=1,启用 JNI 调用检查 默认打开 adb 功能 关闭 Proguard 混淆器 关闭 DE XPREOPT 预先编译优化 如果目标构建变体为 user,则 adb 无法获取 root 权限。 要选择目标构建变体,可以在 make 命令行加入参数,例如: make -j8 PRODUCT-rk3288_box-user make -j8 PRODUCT-rk3288_box-userdebug make -j8 PRODUCT-rk3288_box-eng ==烧写分区映像== 上一步骤的 ./mkimage.sh 会重新打包 boot.img 和 system.img, 并将其它相关的映像文件拷贝到目录 rockdev/Image-rk3288_box/ 中。 以下列出一般固件用到的映像文件: * boot.img :Android 的初始文件映像,负责初始化并加载 system 分区。 * kernel.img :内核映像。 * misc.img :misc 分区映像,负责启动模式切换和急救模式的参数传递。 * recovery.img :急救模式映像。 * resource.img :资源映像,内含开机图片和内核的设备树信息。 * system.img :Android 的 system 分区映像,ext4 文件系统格式。 请参照 如何Android 升级固件 一文来烧写分区映像文件。 如果使用的是 Windows 系统,将上述映像文件拷贝到 AndroidTool (Windows 下的固件升级工具)的 rockdev\Image 目录中,之后参照升级文档烧写分区映像即可,这样的好处是使用默认配置即可,不用修改文件的路径。 在 Windows 下打包统一固件 update.img 很简单,按上一步骤将文件拷贝到 AndroidTool 的 rockdev\Image 目录中,然后运行 rockdev 目录下的 mkupdate.bat 批处理文件即可创建 update.img 并存放到 rockdev\Image 目录里。 update.img 方便固件的发布,供终端用户升级系统使用。一般开发时使用分区映像比较方便。 打包成统一固件 *参考链接:http://wiki.t-firefly.com/zh_CN/Firefly-RK3288/compile_android.html *参考链接:http://wiki.t-firefly.com/zh_CN/Firefly-RK3288/custom_firmware.html *参考链接:http://wiki.t-firefly.com/zh_CN/Firefly-RK3288/adb_debug.html
