查看“V4l2-ctl”的源代码
V4l2-ctl
=简述= v4l2-ctl是V4L2实用程序,允许控制摄像头子系统<ref>https://git.linuxtv.org/v4l-utils.git</ref>。它基于V4L2 Linux内核接口<ref>https://en.wikipedia.org/wiki/Video4Linux</ref> =如何使用= Board $> v4l2-ctl --helpBoard $> v4l2-ctl --help <syntaxhighlight lang="bash"> General/Common options: --all display all information available -C, --get-ctrl=<ctrl>[,<ctrl>...] get the value of the controls [VIDIOC_G_EXT_CTRLS] -c, --set-ctrl=<ctrl>=<val>[,<ctrl>=<val>...] set the value of the controls [VIDIOC_S_EXT_CTRLS] -D, --info show driver info [VIDIOC_QUERYCAP] -d, --device=<dev> use device <dev> instead of /dev/video0 if <dev> starts with a digit, then /dev/video<dev> is used -e, --out-device=<dev> use device <dev> for output streams instead of the default device as set with --device if <dev> starts with a digit, then /dev/video<dev> is used -h, --help display this help message --help-all all options --help-io input/output options --help-misc miscellaneous options --help-overlay overlay format options --help-sdr SDR format options --help-selection crop/selection options --help-stds standards and other video timings options --help-streaming streaming options --help-tuner tuner/modulator options --help-vbi VBI format options --help-vidcap video capture format options --help-vidout vidout output format options --help-edid edid handling options -k, --concise be more concise if possible. -l, --list-ctrls display all controls and their values [VIDIOC_QUERYCTRL] -L, --list-ctrls-menus display all controls and their menus [VIDIOC_QUERYMENU] -r, --subset=<ctrl>[,<offset>,<size>]+ the subset of the N-dimensional array to get/set for control <ctrl>, for every dimension an (<offset>, <size>) tuple is given. -w, --wrapper use the libv4l2 wrapper library. --list-devices list all v4l devices --log-status log the board status in the kernel log [VIDIOC_LOG_STATUS] --get-priority query the current access priority [VIDIOC_G_PRIORITY] --set-priority=<prio> set the new access priority [VIDIOC_S_PRIORITY] <prio> is 1 (background), 2 (interactive) or 3 (record) --silent only set the result code, do not print any messages --sleep=<secs> sleep <secs>, call QUERYCAP and close the file handle --verbose turn on verbose ioctl status reporting </syntaxhighlight> *查看更详细的帮助信息: Board $> v4l2-ctl --help-all <syntaxhighlight lang="bash"> General/Common options: --all display all information available -C, --get-ctrl=<ctrl>[,<ctrl>...] get the value of the controls [VIDIOC_G_EXT_CTRLS] -c, --set-ctrl=<ctrl>=<val>[,<ctrl>=<val>...] set the value of the controls [VIDIOC_S_EXT_CTRLS] -D, --info show driver info [VIDIOC_QUERYCAP] -d, --device=<dev> use device <dev> instead of /dev/video0 if <dev> starts with a digit, then /dev/video<dev> is used -e, --out-device=<dev> use device <dev> for output streams instead of the default device as set with --device if <dev> starts with a digit, then /dev/video<dev> is used -h, --help display this help message --help-all all options --help-io input/output options --help-misc miscellaneous options --help-overlay overlay format options --help-sdr SDR format options --help-selection crop/selection options --help-stds standards and other video timings options --help-streaming streaming options --help-tuner tuner/modulator options --help-vbi VBI format options --help-vidcap video capture format options --help-vidout vidout output format options --help-edid edid handling options -k, --concise be more concise if possible. -l, --list-ctrls display all controls and their values [VIDIOC_QUERYCTRL] -L, --list-ctrls-menus display all controls and their menus [VIDIOC_QUERYMENU] -r, --subset=<ctrl>[,<offset>,<size>]+ the subset of the N-dimensional array to get/set for control <ctrl>, for every dimension an (<offset>, <size>) tuple is given. -w, --wrapper use the libv4l2 wrapper library. --list-devices list all v4l devices --log-status log the board status in the kernel log [VIDIOC_LOG_STATUS] --get-priority query the current access priority [VIDIOC_G_PRIORITY] --set-priority=<prio> set the new access priority [VIDIOC_S_PRIORITY] <prio> is 1 (background), 2 (interactive) or 3 (record) --silent only set the result code, do not print any messages --sleep=<secs> sleep <secs>, call QUERYCAP and close the file handle --verbose turn on verbose ioctl status reporting Tuner/Modulator options: -F, --get-freq query the frequency [VIDIOC_G_FREQUENCY] -f, --set-freq=<freq> set the frequency to <freq> MHz [VIDIOC_S_FREQUENCY] -T, --get-tuner query the tuner settings [VIDIOC_G_TUNER] -t, --set-tuner=<mode> set the audio mode of the tuner [VIDIOC_S_TUNER] Possible values: mono, stereo, lang2, lang1, bilingual --tuner-index=<idx> Use idx as tuner idx for tuner/modulator commands --list-freq-bands display all frequency bands for the tuner/modulator [VIDIOC_ENUM_FREQ_BANDS] --get-modulator query the modulator settings [VIDIOC_G_MODULATOR] --set-modulator=<txsubchans> set the sub-carrier modulation [VIDIOC_S_MODULATOR] <txsubchans> is one of: mono: Modulate as mono mono-rds: Modulate as mono with RDS (radio only) stereo: Modulate as stereo stereo-rds: Modulate as stereo with RDS (radio only) bilingual: Modulate as bilingual mono-sap: Modulate as mono with Second Audio Program stereo-sap: Modulate as stereo with Second Audio Program --freq-seek=dir=<0/1>,wrap=<0/1>,spacing=<hz>,low=<freq>,high=<freq> perform a hardware frequency seek [VIDIOC_S_HW_FREQ_SEEK] dir is 0 (seek downward) or 1 (seek upward) wrap is 0 (do not wrap around) or 1 (wrap around) spacing sets the seek resolution (use 0 for default) low and high set the low and high seek frequency range in MHz Input/Output options: -I, --get-input query the video input [VIDIOC_G_INPUT] -i, --set-input=<num> set the video input to <num> [VIDIOC_S_INPUT] -N, --list-outputs display video outputs [VIDIOC_ENUMOUTPUT] -n, --list-inputs display video inputs [VIDIOC_ENUMINPUT] -O, --get-output query the video output [VIDIOC_G_OUTPUT] -o, --set-output=<num> set the video output to <num> [VIDIOC_S_OUTPUT] --set-audio-output=<num> set the audio output to <num> [VIDIOC_S_AUDOUT] --get-audio-input query the audio input [VIDIOC_G_AUDIO] --set-audio-input=<num> set the audio input to <num> [VIDIOC_S_AUDIO] --get-audio-output query the audio output [VIDIOC_G_AUDOUT] --set-audio-output=<num> set the audio output to <num> [VIDIOC_S_AUDOUT] --list-audio-outputs display audio outputs [VIDIOC_ENUMAUDOUT] --list-audio-inputs display audio inputs [VIDIOC_ENUMAUDIO] Standards/Timings options: --list-standards display supported video standards [VIDIOC_ENUMSTD] -S, --get-standard query the video standard [VIDIOC_G_STD] -s, --set-standard=<num> set the video standard to <num> [VIDIOC_S_STD] <num> a numerical v4l2_std value, or one of: pal or pal-X (X = B/G/H/N/Nc/I/D/K/M/60) (V4L2_STD_PAL) ntsc or ntsc-X (X = M/J/K) (V4L2_STD_NTSC) secam or secam-X (X = B/G/H/D/K/L/Lc) (V4L2_STD_SECAM) --get-detected-standard display detected input video standard [VIDIOC_QUERYSTD] --list-dv-timings list supp. standard dv timings [VIDIOC_ENUM_DV_TIMINGS] --set-dv-bt-timings query: use the output of VIDIOC_QUERY_DV_TIMINGS index=<index>: use the index as provided by --list-dv-timings or specify timings using cvt/gtf options as follows: cvt/gtf,width=<width>,height=<height>,fps=<frames per sec> interlaced=<0/1>,reduced-blanking=<0/1/2>,reduced-fps=<0/1> The value of reduced-blanking, if greater than 0, indicates that reduced blanking is to be used and the value indicate the version. For gtf, there is no version 2 for reduced blanking, and the value 1 or 2 will give same results. reduced-fps = 1, slows down pixel clock by factor of 1000 / 1001, allowing to support NTSC frame rates like 29.97 or 59.94. Reduced fps flag takes effect only with reduced blanking version 2 and, when refresh rate is an integer multiple of 6, say, fps = 24,30,60 etc. or update all or part of the current timings fields: width=<width>,height=<height>,interlaced=<0/1>, polarities=<polarities mask>,pixelclock=<pixelclock Hz>, hfp=<horizontal front porch>,hs=<horizontal sync>, hbp=<horizontal back porch>,vfp=<vertical front porch>, vs=<vertical sync>,vbp=<vertical back porch>, il_vfp=<vertical front porch for bottom field>, il_vs=<vertical sync for bottom field>, il_vbp=<vertical back porch for bottom field>. clear: start with zeroed timings instead of the current timings. set the digital video timings according to the BT 656/1120 standard [VIDIOC_S_DV_TIMINGS] --get-dv-timings get the digital video timings in use [VIDIOC_G_DV_TIMINGS] --query-dv-timings query the detected dv timings [VIDIOC_QUERY_DV_TIMINGS] --get-dv-timings-cap get the dv timings capabilities [VIDIOC_DV_TIMINGS_CAP] Video Capture Formats options: --list-formats display supported video formats [VIDIOC_ENUM_FMT] --list-formats-ext display supported video formats including frame sizes and intervals --list-framesizes=<f> list supported framesizes for pixelformat <f> [VIDIOC_ENUM_FRAMESIZES] pixelformat is the fourcc value as a string --list-frameintervals=width=<w>,height=<h>,pixelformat=<f> list supported frame intervals for pixelformat <f> and the given width and height [VIDIOC_ENUM_FRAMEINTERVALS] pixelformat is the fourcc value as a string --list-fields list supported fields for the current format -V, --get-fmt-video query the video capture format [VIDIOC_G_FMT] -v, --set-fmt-video --try-fmt-video=width=<w>,height=<h>,pixelformat=<pf>,field=<f>,colorspace=<c>, xfer=<xf>,ycbcr=<y>,quantization=<q>,premul-alpha,bytesperline=<bpl> set/try the video capture format [VIDIOC_S/TRY_FMT] pixelformat is either the format index as reported by --list-formats, or the fourcc value as a string. The bytesperline option can be used multiple times, once for each plane. premul-alpha sets V4L2_PIX_FMT_FLAG_PREMUL_ALPHA. <f> can be one of the following field layouts: any, none, top, bottom, interlaced, seq_tb, seq_bt, alternate, interlaced_tb, interlaced_bt <c> can be one of the following colorspaces: smpte170m, smpte240m, rec709, 470m, 470bg, jpeg, srgb, adobergb, bt2020, dcip3 <xf> can be one of the following transfer functions: default, 709, srgb, adobergb, smpte240m, smpte2084, dcip3, none <y> can be one of the following Y'CbCr encodings: default, 601, 709, xv601, xv709, bt2020, bt2020c, smpte240m <q> can be one of the following quantization methods: default, full-range, lim-range Video Output Formats options: --list-formats-out display supported video output formats [VIDIOC_ENUM_FMT] --list-fields-out list supported fields for the current output format --get-fmt-video-out query the video output format [VIDIOC_G_FMT] --set-fmt-video-out --try-fmt-video-out=width=<w>,height=<h>,pixelformat=<pf>,field=<f>,colorspace=<c>, xfer=<xf>,ycbcr=<y>,quantization=<q>,premul-alpha,bytesperline=<bpl> set/try the video output format [VIDIOC_S/TRY_FMT] pixelformat is either the format index as reported by --list-formats-out, or the fourcc value as a string. premul-alpha sets V4L2_PIX_FMT_FLAG_PREMUL_ALPHA. The bytesperline option can be used multiple times, once for each plane. <f> can be one of the following field layouts: any, none, top, bottom, interlaced, seq_tb, seq_bt, alternate, interlaced_tb, interlaced_bt <c> can be one of the following colorspaces: smpte170m, smpte240m, rec709, 470m, 470bg, jpeg, srgb, adobergb, bt2020, dcip3 <xf> can be one of the following transfer functions: default, 709, srgb, adobergb, smpte240m, smpte2084, dcip3, none <y> can be one of the following Y'CbCr encodings: default, 601, 709, xv601, xv709, bt2020, bt2020c, smpte240m <q> can be one of the following quantization methods: default, full-range, lim-range Video Overlay options: --list-formats-overlay display supported overlay formats [VIDIOC_ENUM_FMT] --find-fb find the fb device corresponding with the overlay --overlay=<on> turn overlay on (1) or off (0) (VIDIOC_OVERLAY) --get-fmt-overlay query the video or video output overlay format [VIDIOC_G_FMT] --set-fmt-overlay --try-fmt-overlay=chromakey=<key>,global_alpha=<alpha>, top=<t>,left=<l>,width=<w>,height=<h>,field=<f> set/try the video or video output overlay format [VIDIOC_TRY/S_FMT] <f> can be one of: any, none, top, bottom, interlaced, seq_tb, seq_bt, alternate, interlaced_tb, interlaced_bt If the width or height changed then the old clip list and bitmap will be invalidated. --clear-clips clear any old clips, to be used in combination with --try/set-fmt-overlay --clear-bitmap clear any old bitmap, to be used in combination with --try/set-fmt-overlay --add-clip=top=<t>,left=<l>,width=<w>,height=<h> Add an entry to the clip list. May be used multiple times. This clip list will be passed to --try/set-fmt-overlay --add-bitmap=top=<t>,left=<l>,width=<w>,height=<h> Set the bits in the given rectangle in the bitmap to 1. May be used multiple times. The bitmap will be passed to --try/set-fmt-overlay --get-fbuf query the overlay framebuffer data [VIDIOC_G_FBUF] --set-fbuf=chromakey=<b>,src_chromakey=<b>,global_alpha=<b>,local_alpha=<b>,local_inv_alpha=<b>,fb=<fb> set the overlay framebuffer [VIDIOC_S_FBUF] <b> is 0 or 1 <fb> is the framebuffer device (/dev/fbX) if <fb> starts with a digit, then /dev/fb<fb> is used VBI Formats options: --get-sliced-vbi-cap query the sliced VBI capture capabilities [VIDIOC_G_SLICED_VBI_CAP] --get-sliced-vbi-out-cap query the sliced VBI output capabilities [VIDIOC_G_SLICED_VBI_CAP] -B, --get-fmt-sliced-vbi query the sliced VBI capture format [VIDIOC_G_FMT] --get-fmt-sliced-vbi-out query the sliced VBI output format [VIDIOC_G_FMT] -b, --set-fmt-sliced-vbi --try-fmt-sliced-vbi --set-fmt-sliced-vbi-out --try-fmt-sliced-vbi-out=<mode> set/try the sliced VBI capture/output format to <mode> [VIDIOC_S/TRY_FMT], <mode> is a comma separated list of: off: turn off sliced VBI (cannot be combined with other modes) teletext: teletext (PAL/SECAM) cc: closed caption (NTSC) wss: widescreen signal (PAL/SECAM) vps: VPS (PAL/SECAM) --get-fmt-vbi query the VBI capture format [VIDIOC_G_FMT] --get-fmt-vbi-out query the VBI output format [VIDIOC_G_FMT] --set-fmt-vbi --try-fmt-vbi --set-fmt-vbi-out --try-fmt-vbi-out=samplingrate=<r>,offset=<o>,samplesperline=<spl>, start0=<s0>,count0=<c0>,start1=<s1>,count1=<c1> set/try the raw VBI capture/output format [VIDIOC_S/TRY_FMT] samplingrate: samples per second offset: horizontal offset in samples samplesperline: samples per line start0: start line number of the first field count0: number of lines in the first field start1: start line number of the second field count1: number of lines in the second field SDR Formats options: --list-formats-sdr display supported SDR capture formats [VIDIOC_ENUM_FMT] --get-fmt-sdr query the SDR capture format [VIDIOC_G_FMT] --set-fmt-sdr=<f> set the SDR capture format [VIDIOC_S_FMT] parameter is either the format index as reported by --list-formats-sdr-cap, or the fourcc value as a string --try-fmt-sdr=<f> try the SDR capture format [VIDIOC_TRY_FMT] parameter is either the format index as reported by --list-formats-sdr-cap, or the fourcc value as a string --list-formats-sdr-out display supported SDR output formats [VIDIOC_ENUM_FMT] --get-fmt-sdr-out query the SDR output format [VIDIOC_G_FMT] --set-fmt-sdr-out=<f> set the SDR output format [VIDIOC_S_FMT] parameter is either the format index as reported by --list-formats-sdr-out, or the fourcc value as a string --try-fmt-sdr-out=<f> try the SDR output format [VIDIOC_TRY_FMT] parameter is either the format index as reported by --list-formats-sdr-out, or the fourcc value as a string Selection/Cropping options: --get-cropcap query the crop capabilities [VIDIOC_CROPCAP] --get-crop query the video capture crop window [VIDIOC_G_CROP] --set-crop=top=<x>,left=<y>,width=<w>,height=<h> set the video capture crop window [VIDIOC_S_CROP] --get-cropcap-output query crop capabilities for video output [VIDIOC_CROPCAP] --get-crop-output query the video output crop window [VIDIOC_G_CROP] --set-crop-output=top=<x>,left=<y>,width=<w>,height=<h> set the video output crop window [VIDIOC_S_CROP] --get-cropcap-overlay query crop capabilities for video overlay [VIDIOC_CROPCAP] --get-crop-overlay query the video overlay crop window [VIDIOC_G_CROP] --set-crop-overlay=top=<x>,left=<y>,width=<w>,height=<h> set the video overlay crop window [VIDIOC_S_CROP] --get-cropcap-output-overlay query the crop capabilities for video output overlays [VIDIOC_CROPCAP] --get-crop-output-overlay query the video output overlay crop window [VIDIOC_G_CROP] --set-crop-output-overlay=top=<x>,left=<y>,width=<w>,height=<h> set the video output overlay crop window [VIDIOC_S_CROP] --get-selection=target=<target> query the video capture selection rectangle [VIDIOC_G_SELECTION] See --set-selection command for the valid <target> values. --set-selection=target=<target>,flags=<flags>,top=<x>,left=<y>,width=<w>,height=<h> set the video capture selection rectangle [VIDIOC_S_SELECTION] target=crop|crop_bounds|crop_default|compose|compose_bounds| compose_default|compose_padded|native_size flags=le|ge --get-selection-output=target=<target> query the video output selection rectangle [VIDIOC_G_SELECTION] See --set-selection command for the valid <target> values. --set-selection-output=target=<target>,flags=<flags>,top=<x>,left=<y>,width=<w>,height=<h> set the video output selection rectangle [VIDIOC_S_SELECTION] See --set-selection command for the arguments. Miscellaneous options: --wait-for-event=<event> wait for an event [VIDIOC_DQEVENT] <event> is the event number or one of: eos, vsync, ctrl=<id>, frame_sync, source_change=<pad>, motion_det where <id> is the name of the control and where <pad> is the index of the pad or input --poll-for-event=<event> poll for an event [VIDIOC_DQEVENT] see --wait-for-event for possible events -P, --get-parm display video parameters [VIDIOC_G_PARM] -p, --set-parm=<fps> set video framerate in <fps> [VIDIOC_S_PARM] --get-output-parm display output video parameters [VIDIOC_G_PARM] --set-output-parm=<fps> set output video framerate in <fps> [VIDIOC_S_PARM] --get-jpeg-comp query the JPEG compression [VIDIOC_G_JPEGCOMP] --set-jpeg-comp=quality=<q>,markers=<markers>,comment=<c>,app<n>=<a> set the JPEG compression [VIDIOC_S_JPEGCOMP] <n> is the app segment: 0-9/a-f, <a> is the actual string. <markers> is a colon separated list of: dht: Define Huffman Tables dqt: Define Quantization Tables dri: Define Restart Interval --encoder-cmd=cmd=<cmd>,flags=<flags> Send a command to the encoder [VIDIOC_ENCODER_CMD] cmd=start|stop|pause|resume flags=stop_at_gop_end --try-encoder-cmd=cmd=<cmd>,flags=<flags> Try an encoder command [VIDIOC_TRY_ENCODER_CMD] See --encoder-cmd for the arguments. --decoder-cmd=cmd=<cmd>,flags=<flags>,stop_pts=<pts>,start_speed=<speed>, start_format=<none|gop> Send a command to the decoder [VIDIOC_DECODER_CMD] cmd=start|stop|pause|resume flags=start_mute_audio|pause_to_black|stop_to_black| stop_immediately --try-decoder-cmd=cmd=<cmd>,flags=<flags> Try a decoder command [VIDIOC_TRY_DECODER_CMD] See --decoder-cmd for the arguments. Video Streaming options: --stream-count=<count> stream <count> buffers. The default is to keep streaming forever. This count does not include the number of initial skipped buffers as is passed by --stream-skip. --stream-skip=<count> skip the first <count> buffers. The default is 0. --stream-sleep=<count> sleep for 1 second every <count> buffers. If <count> is 0, then sleep forever right after streaming starts. The default is -1 (never sleep). --stream-to=<file> stream to this file. The default is to discard the data. If <file> is '-', then the data is written to stdout and the --silent option is turned on automatically. --stream-to-host=<hostname[:port]> stream to this host. The default port is 8362. --stream-poll use non-blocking mode and select() to stream. --stream-mmap=<count> capture video using mmap() [VIDIOC_(D)QBUF] count: the number of buffers to allocate. The default is 3. --stream-user=<count> capture video using user pointers [VIDIOC_(D)QBUF] count: the number of buffers to allocate. The default is 3. --stream-dmabuf capture video using dmabuf [VIDIOC_(D)QBUF] Requires a corresponding --stream-out-mmap option. --stream-from=<file> stream from this file. The default is to generate a pattern. If <file> is '-', then the data is read from stdin. --stream-from-host=<hostname[:port]> stream from this host. The default port is 8362. --stream-loop loop when the end of the file we are streaming from is reached. The default is to stop. --stream-out-pattern=<count> choose output test pattern. The default is 0. --stream-out-square show a square in the middle of the output test pattern. --stream-out-border show a border around the pillar/letterboxed video. --stream-out-sav insert an SAV code in every line. --stream-out-eav insert an EAV code in every line. --stream-out-pixel-aspect=<aspect select a pixel aspect ratio. The default is to autodetect. <aspect> can be one of: square, ntsc, pal --stream-out-video-aspect=<aspect select a video aspect ratio. The default is to use the frame ratio. <aspect> can be one of: 4x3, 14x9, 16x9, anamorphic --stream-out-alpha=<alpha-value> value to use for the alpha component, range 0-255. The default is 0. --stream-out-alpha-red-only only use the --stream-out-alpha value for the red colors, for all others use 0. --stream-out-rgb-lim-range Encode RGB values as limited [16-235] instead of full range. --stream-out-hor-speed=<speed> choose speed for horizontal movement. The default is 0, and the range is [-3...3]. --stream-out-vert-speed=<speed> choose speed for vertical movement. The default is 0, and the range is [-3...3]. --stream-out-perc-fill=<percentage> percentage of the frame to actually fill. The default is 100%. --stream-out-mmap=<count> output video using mmap() [VIDIOC_(D)QBUF] count: the number of buffers to allocate. The default is 4. --stream-out-user=<count> output video using user pointers [VIDIOC_(D)QBUF] count: the number of buffers to allocate. The default is 4. --stream-out-dmabuf output video using dmabuf [VIDIOC_(D)QBUF] Requires a corresponding --stream-mmap option. --list-patterns list available patterns for use with --stream-pattern. --list-buffers list all video buffers [VIDIOC_QUERYBUF] --list-buffers-out list all video output buffers [VIDIOC_QUERYBUF] --list-buffers-vbi list all VBI buffers [VIDIOC_QUERYBUF] --list-buffers-vbi-out list all VBI output buffers [VIDIOC_QUERYBUF] --list-buffers-sliced-vbi list all sliced VBI buffers [VIDIOC_QUERYBUF] --list-buffers-sliced-vbi-out list all sliced VBI output buffers [VIDIOC_QUERYBUF] --list-buffers-sdr list all SDR RX buffers [VIDIOC_QUERYBUF] --list-buffers-sdr-out list all SDR TX buffers [VIDIOC_QUERYBUF] EDID options: --set-edid=pad=<pad>[,type=<type>|file=<file>][,format=<fmt>][modifiers] <pad> is the input or output index for which to set the EDID. <type> can be 'hdmi', 'hdmi-4k-170mhz', 'hdmi-4k-300mhz', 'hdmi-4k-600mhz', 'dvid' or 'vga'. A predefined EDID suitable for that connector type will be set. It has a 1920x1080p60 native resolution for the non-4k variants and a 3840x2160 resolution for the 4k variants (4kp30 YCbCr 4:2:0 for 170mhz, 4kp30 for 300 mhz and 4kp60 for 600 mhz). If <file> is '-', then the data is read from stdin, otherwise it is read from the given file. The file format must be in hex as in get-edid. The 'type' or 'file' arguments are mutually exclusive. One of the two must be specified. <fmt> is one of: hex: hex numbers in ascii text (default) raw: raw binary EDID content [modifiers] is a comma-separate list of EDID modifiers: CEA-861 Header modifiers: underscan: toggle the underscan bit. audio: toggle the audio bit. ycbcr444: toggle the YCbCr 4:4:4 bit. ycbcr422: toggle the YCbCr 4:2:2 bit. Speaker Allocation Data Block modifiers: fl-fr: Front Left and Front Right. lfe: Low Frequence Effects. fc: Front Center. rl-rr: Rear Left and Rear Right. rc: Rear Center. flc-frc: Front Left Center and Front Right Center. rlc-rrc: Rear Left Center and Rear Right Center. flw-frw: Front Left Wide and Front Right Wide. flh-frh: Front Left High and Front Right High. tc: Top Center. fch: Front Center High. HDMI Vendor-Specific Data Block modifiers: pa=<pa>: change the physical address. y444: toggle the YCbCr 4:4:4 Deep Color bit. 30-bit: toggle the 30 bits/pixel bit. 36-bit: toggle the 36 bits/pixel bit. 48-bit: toggle the 48 bits/pixel bit. graphics: toggle the Graphics Content Type bit. photo: toggle the Photo Content Type bit. cinema: toggle the Cinema Content Type bit. game: toggle the Game Content Type bit. HDMI Forum Vendor-Specific Data Block modifiers: scdc: toggle the SCDC Present bit. CEA-861 Video Capability Descriptor modifiers: qy: toggle the QY YCC Quantization Range bit. qs: toggle the QS RGB Quantization Range bit. s-pt=<0-3>: set the PT Preferred Format Over/underscan bits. s-it=<0-3>: set the IT Over/underscan bits. s-ce=<0-3>: set the CE Over/underscan bits. CEA-861 Colorimetry Data Block modifiers: xvycc-601: toggle the xvYCC 601 bit. xvycc-709: toggle the xvYCC 709 bit. sycc: toggle the sYCC 601 bit. adobe-ycc: toggle the Adobe YCC 601 bit. adobe-rgb: toggle the Adobe RGB bit. bt2020-rgb: toggle the BT2020 RGB bit. bt2020-ycc: toggle the BT2020 YCC bit. bt2020-cycc: toggle the BT2020 cYCC bit. CEA-861 HDR Static Metadata Data Block modifiers: sdr: toggle the Traditional gamma SDR bit. hdr: toggle the Traditional gamma HDR bit. smpte2084: toggle the SMPTE ST 2084 bit. --clear-edid=<pad> <pad> is the input or output index for which to clear the EDID. --info-edid=<pad> print the current EDID's modifiers <pad> is the input or output index for which to get the EDID. --get-edid=pad=<pad>,startblock=<startblock>,blocks=<blocks>,format=<fmt>,file=<file> <pad> is the input or output index for which to get the EDID. <startblock> is the first block number you want to read. Default 0. <blocks> is the number of blocks you want to read. Default is all blocks. <fmt> is one of: hex: hex numbers in ascii text (default) raw: can be piped directly into the edid-decode tool carray: c-program struct If <file> is '-' or not the 'file' argument is not supplied, then the data is written to stdout. --fix-edid-checksums If specified then any checksum errors will be fixed silently. </syntaxhighlight> =参考示例= :有关使用示例,请参阅 [[V4L2_camera_overview | 摄像机概述]] =参考资料= <references /> [[Category:Linux_Operating_System]] [[Category:Visual]] [[Category:V4L2]]
V4l2-ctl
