查看“模板:EcosystemRelease”的源代码
模板
模板:EcosystemRelease
<noinclude> ==Usage== The [[Template:EcosystemRelease|EcosystemRelease]] template is used '''to indicate for which ecosystem release revision(s)''' of the flow associated with this wiki (e.g. v1.y.z ,or v2.y.z, or...), '''an article part (chapter, paragraph, table...) is valid'''. Per default (i.e. if this template is not used), any part of an article is valid for all ecosystem release revisions for which the entire article is valid. It outputs a "standardized" string that might be used to name an article part. Usage: <nowiki>{{</nowiki>EcosystemRelease | revision={{HighlightParam|<revision>}} | range ={{HighlightParam|<range>}} | revision2={{HighlightParam|<revision2>}}}} Where: * {{HighlightParam|<revision>}} is the '''mandatory''' ecosystem release revision for which the article part is valid. ** The possible values for this parameter are available in the [[Template:EcosystemRelease/Revision|EcosystemRelease/Revision]] template. ** The optional {{HighlightParam|<range>}} and {{HighlightParam|<revision2>}} parameters allow to define a range of revisions. * {{HighlightParam|<range>}} is the '''optional''' range of the ecosystem release revisions for which the article part is valid. The possible values are: ** '''and before''': the article part is valid only for the revision(s) less than or equal to {{HighlightParam|<revision>}} ** '''and after''': the article part is valid only for the revision(s) greater than or equal to {{HighlightParam|<revision>}} ** '''to''': the article part is only valid from {{HighlightParam|<revision>}} to {{HighlightParam|<revision2>}} * {{HighlightParam|<revision2>}} is the '''mandatory''' ecosystem release upper revision for which the article part is valid, '''when {{HighlightParam|<range>}} is set to "to'''"; in this case, {{HighlightParam|<revision>}} becomes the lower revision for which the article part is valid. ** This parameter is ignored if {{HighlightParam|<range>}} is either not set, or set to another value than "'''to'''". If the mouse is left over a revision (or the <sup>[[File:More_info.png|15px|link=]]</sup> icon), '''a popup window''' shows, for that revision: * the versions of the Linux kernel, U-Boot, TF-A and OP-TEE * the version of the STM32Cube MPU Package * the version of OpenEmbedded * the version of Android This information comes from the [[Template:EcosystemRelease/Components|EcosystemRelease/Components]] template. ==Basic examples== {| class="st-table" ! style="width: 50%;" | You type !! You get |- | A specific revision (revision 1.2.0) <pre style="white-space: pre-wrap;"> {{EcosystemRelease | revision=1.2.0}} </pre> | {{EcosystemRelease | revision=1.2.0}} |- | Revisions that are lower than or equal to a revision <pre style="white-space: pre-wrap;"> {{EcosystemRelease | revision=x.1.0 | range=and before}} </pre> | {{EcosystemRelease | revision=x.1.0 | range=and before}} |- | Revisions that are greater than or equal to a revision <pre style="white-space: pre-wrap;"> {{EcosystemRelease | revision=x.1.0 | range=and after}} </pre> | {{EcosystemRelease | revision=x.1.0 | range=and after}} |- | Range of revisions <pre style="white-space: pre-wrap;"> {{EcosystemRelease | revision=x.0.0 | range=to | revision2=x.1.0}} </pre> | {{EcosystemRelease | revision=x.0.0 | range=to | revision2=x.1.0}} |} ==More examples== {| class="st-table" ! style="width: 50%;" | You type !! You get |- | Revision 1.1.0 <pre style="white-space: pre-wrap;"> {{EcosystemRelease | revision=1.1.0}} </pre> | {{EcosystemRelease | revision=1.1.0}} |- | Revision 1.0.0 <pre style="white-space: pre-wrap;"> {{EcosystemRelease | revision=1.0.0}} </pre> | {{EcosystemRelease | revision=1.0.0}} |- | Former revision that is part of a flow that is not the one associated with this wiki. <pre style="white-space: pre-wrap;"> {{EcosystemRelease | revision=0.y.0}} </pre> | {{EcosystemRelease | revision=0.y.0}} |- | Unspecified revision <pre style="white-space: pre-wrap;"> {{EcosystemRelease}} </pre> | {{EcosystemRelease}} |- | Unknown revision <pre style="white-space: pre-wrap;"> {{EcosystemRelease | revision=10.20.30}} </pre> | {{EcosystemRelease | revision=10.20.30}} |- | Unspecified revision2 <pre style="white-space: pre-wrap;"> {{EcosystemRelease | revision=x.1.0 | range=to}} </pre> | {{EcosystemRelease | revision=x.1.0 | range=to}} |- | Unknown revision2 <pre style="white-space: pre-wrap;"> {{EcosystemRelease | revision=x.1.0 | range=to | revision2=10.20.30}} </pre> | {{EcosystemRelease | revision=x.1.0 | range=to | revision2=10.20.30}} |- | Ignored revision2 <pre style="white-space: pre-wrap;"> {{EcosystemRelease | revision=x.0.0 | range=and after | revision2=x.1.0}} </pre> | {{EcosystemRelease | revision=x.0.0 | range=and after | revision2=x.1.0}} |- | Unknown range <pre style="white-space: pre-wrap;"> {{EcosystemRelease | revision=x.1.0 | range=error}} </pre> | {{EcosystemRelease | revision=x.1.0 | range=error}} |- | Check that there's no space before and after the text <pre style="white-space: pre-wrap;"> BEFORE{{EcosystemRelease | revision=x.0.0}}AFTER<br> BEFORE{{EcosystemRelease | revision=x.1.0 | range=and before}}AFTER<br> BEFORE{{EcosystemRelease | revision=x.1.0 | range=and after}}AFTER<br> BEFORE{{EcosystemRelease | revision=x.0.0 | range=to | revision2=x.1.0}}AFTER </pre> | BEFORE{{EcosystemRelease | revision=x.0.0}}AFTER<br> BEFORE{{EcosystemRelease | revision=x.1.0 | range=and before}}AFTER<br> BEFORE{{EcosystemRelease | revision=x.1.0 | range=and after}}AFTER<br> BEFORE{{EcosystemRelease | revision=x.0.0 | range=to | revision2=x.1.0}}AFTER |} ==Code== {{UpdateNeededForNewRelease| * Update the first "basic example" with the latest revision, and add in "more examples" the legacy revisions * Update, if needed, the below sentence "not valid in the flow (v1.y.z) associated"}} </noinclude>ecosystem release {{#switch:{{EcosystemRelease/Revision | revision={{{revision|}}}}} | unknown = <span title="This revision value is not valid">{{Highlight|unknown revision {{{revision|}}}}} <sup>[[File:Warning.png|15px|link=]]</sup></span> | former = <span title="This former revision is not valid in the flow (v1.y.z) associated with this wiki">{{Highlight|no more valid revision {{{revision|}}}}} <sup>[[File:Warning.png|15px|link=]]</sup></span>{{#set:Ecosystem release=no more valid revision {{{revision}}}}} | #default = {{#switch: {{{range|}}} | and before = ≤ | and after = ≥ }} <span title="{{EcosystemRelease/Components | revision={{{revision|}}}}}">v{{{revision}}} <sup>[[File:More_info.png|15px|link=]]</sup></span> {{#switch: {{{range}}} | and before | and after = | to = to {{#switch:{{EcosystemRelease/Revision | revision={{{revision2|}}}}} | unknown = <span title="This revision value is not valid">{{Highlight|unknown revision {{{revision2|}}}}} <sup>[[File:Warning.png|15px|link=]]</sup></span> | #default = <span title="{{EcosystemRelease/Components | revision={{{revision2|}}}}}">{{{revision2}}} <sup>[[File:More_info.png|15px|link=]]</sup></span> }} | #default = {{#if: {{{range|}}} | <span title="This range value is not valid">{{Highlight|unknown range {{{range|}}}}} <sup>[[File:Warning.png|15px|link=]]</sup></span> |}} }}{{#set:Ecosystem release={{{revision}}}}} }}
模板:EcosystemRelease
模板:EcosystemRelease/Component
模板:EcosystemRelease/Components
模板:EcosystemRelease/Revision
模板:HighlightParam
模板:UpdateNeededForNewRelease
模板:EcosystemRelease
