查看“Mjpg-streamer”的源代码
Mjpg-streamer
=查看摄像头数据= ==列出所有摄像头设备== <syntaxhighlight lang="bash"> [root@imx6ull:~]# v4l2-ctl --list-devices pxp (pxp_v4l2): /dev/video0 USB 2.0 Camera (usb-ci_hdrc.1-1.3): /dev/video1 </syntaxhighlight> ==查看摄像头详细信息== <syntaxhighlight lang="bash"> [root@imx6ull:~]# v4l2-ctl -L -d /dev/video1 brightness 0x00980900 (int) : min=-255 max=255 step=1 default=0 value=0 contrast 0x00980901 (int) : min=0 max=30 step=1 default=15 value=15 saturation 0x00980902 (int) : min=0 max=127 step=1 default=30 value=30 hue 0x00980903 (int) : min=-16000 max=16000 step=100 default=0 value=0 white_balance_temperature_auto 0x0098090c (bool) : default=1 value=1 gamma 0x00980910 (int) : min=20 max=250 step=1 default=98 value=98 power_line_frequency 0x00980918 (menu) : min=0 max=2 default=1 value=1 0: Disabled 1: 50 Hz 2: 60 Hz white_balance_temperature 0x0098091a (int) : min=2500 max=7000 step=1 default=5000 value=5000 flags=inactive sharpness 0x0098091b (int) : min=0 max=15 step=1 default=2 value=2 backlight_compensation 0x0098091c (int) : min=0 max=2 step=1 default=1 value=1 </syntaxhighlight> ==查看摄像头支持的像素格式和分辨率== <syntaxhighlight lang="bash"> [root@imx6ull:~]# v4l2-ctl --list-formats-ext -d /dev/video1 ioctl: VIDIOC_ENUM_FMT Type: Video Capture [0]: 'YUYV' (YUYV 4:2:2) Size: Discrete 640x480 Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.050s (20.000 fps) Interval: Discrete 0.067s (15.000 fps) Interval: Discrete 0.100s (10.000 fps) Interval: Discrete 0.200s (5.000 fps) Size: Discrete 160x120 Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.050s (20.000 fps) Interval: Discrete 0.067s (15.000 fps) Interval: Discrete 0.100s (10.000 fps) Interval: Discrete 0.200s (5.000 fps) Size: Discrete 320x240 Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.050s (20.000 fps) Interval: Discrete 0.067s (15.000 fps) Interval: Discrete 0.100s (10.000 fps) Interval: Discrete 0.200s (5.000 fps) Size: Discrete 352x288 Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.050s (20.000 fps) Interval: Discrete 0.067s (15.000 fps) Interval: Discrete 0.100s (10.000 fps) Interval: Discrete 0.200s (5.000 fps) Size: Discrete 800x600 Interval: Discrete 0.067s (15.000 fps) Interval: Discrete 0.100s (10.000 fps) Interval: Discrete 0.200s (5.000 fps) Size: Discrete 1280x720 Interval: Discrete 0.067s (15.000 fps) Interval: Discrete 0.100s (10.000 fps) Interval: Discrete 0.200s (5.000 fps) Size: Discrete 1280x1024 Interval: Discrete 0.083s (12.000 fps) Interval: Discrete 0.100s (10.000 fps) Interval: Discrete 0.200s (5.000 fps) Size: Discrete 1600x1200 Interval: Discrete 0.111s (9.000 fps) Interval: Discrete 0.200s (5.000 fps) [1]: 'MJPG' (Motion-JPEG, compressed) Size: Discrete 640x480 Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.050s (20.000 fps) Interval: Discrete 0.067s (15.000 fps) Interval: Discrete 0.100s (10.000 fps) Interval: Discrete 0.200s (5.000 fps) Size: Discrete 160x120 Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.050s (20.000 fps) Interval: Discrete 0.067s (15.000 fps) Interval: Discrete 0.100s (10.000 fps) Interval: Discrete 0.200s (5.000 fps) Size: Discrete 320x240 Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.050s (20.000 fps) Interval: Discrete 0.067s (15.000 fps) Interval: Discrete 0.100s (10.000 fps) Interval: Discrete 0.200s (5.000 fps) Size: Discrete 352x288 Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.050s (20.000 fps) Interval: Discrete 0.067s (15.000 fps) Interval: Discrete 0.100s (10.000 fps) Interval: Discrete 0.200s (5.000 fps) Size: Discrete 800x600 Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.050s (20.000 fps) Interval: Discrete 0.067s (15.000 fps) Interval: Discrete 0.100s (10.000 fps) Interval: Discrete 0.200s (5.000 fps) Size: Discrete 1280x720 Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.050s (20.000 fps) Interval: Discrete 0.067s (15.000 fps) Interval: Discrete 0.100s (10.000 fps) Interval: Discrete 0.200s (5.000 fps) Size: Discrete 1280x1024 Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.050s (20.000 fps) Interval: Discrete 0.067s (15.000 fps) Interval: Discrete 0.100s (10.000 fps) Interval: Discrete 0.200s (5.000 fps) </syntaxhighlight> =使用mjpg_streamer预览摄像头数据= ==查看开发板IP地址== <syntaxhighlight lang="bash"> [root@imx6ull:~]# ifconfig eth0 Link encap:Ethernet HWaddr 00:01:3F:2D:3E:4D UP BROADCAST MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) eth1 Link encap:Ethernet HWaddr 00:01:1F:2D:3E:4D inet addr:192.168.1.21 Bcast:192.168.1.255 Mask:255.255.255.0 inet6 addr: fdfd:3597:aa7a:0:201:1fff:fe2d:3e4d/64 Scope:Global inet6 addr: fe80::201:1fff:fe2d:3e4d/64 Scope:Link inet6 addr: fdfd:3597:aa7a::914/64 Scope:Global UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:558 errors:0 dropped:0 overruns:0 frame:0 TX packets:291 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:221870 (216.6 KiB) TX bytes:29419 (28.7 KiB) lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 inet6 addr: ::1/128 Scope:Host UP LOOPBACK RUNNING MTU:65536 Metric:1 RX packets:7756 errors:0 dropped:0 overruns:0 frame:0 TX packets:7756 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1 RX bytes:468263 (457.2 KiB) TX bytes:468263 (457.2 KiB) </syntaxhighlight> ==mjpg_streamer参数讲解== :使用mjpg_streamer -h 查看帮助信息。 <syntaxhighlight lang="bash"> [root@imx6ull:~]# mjpg_streamer -h ----------------------------------------------------------------------- Usage: mjpg_streamer -i | --input "<input-plugin.so> [parameters]" -o | --output "<output-plugin.so> [parameters]" [-h | --help ]........: display this help [-v | --version ].....: display version information [-b | --background]...: fork to the background, daemon mode ----------------------------------------------------------------------- Example #1: To open an UVC webcam "/dev/video1" and stream it via HTTP: mjpg_streamer -i "input_uvc.so -d /dev/video1" -o "output_http.so" ----------------------------------------------------------------------- Example #2: To open an UVC webcam and stream via HTTP port 8090: mjpg_streamer -i "input_uvc.so" -o "output_http.so -p 8090" ----------------------------------------------------------------------- Example #3: To get help for a certain input plugin: mjpg_streamer -i "input_uvc.so --help" ----------------------------------------------------------------------- In case the modules (=plugins) can not be found: * Set the default search path for the modules with: export LD_LIBRARY_PATH=/path/to/plugins, * or put the plugins into the "/lib/" or "/usr/lib" folder, * or instead of just providing the plugin file name, use a complete path and filename: mjpg_streamer -i "/path/to/modules/input_uvc.so" ----------------------------------------------------------------------- </syntaxhighlight> :得知mjpg_streamer后需要接-i和-o两个参数,再分别看这两个参数提供的不同so插件文件支持哪些选项。 :可选的-h查询帮助信息、-v查询版本信息、-b后台执行就不多介绍了。 :输入so插件包含:input_uvc.so、input_testpicture.so、(input_file.so、input_ptp2.so、input_http.so) :输出so插件包含:output_http.so、(output_file.so、output_udp.so、output_rtsp.so、output_viewer.so) :其中括号部分,我这个Buildroot的mjpg_streamer版本没有提供。 *参考页面 https://hceng.cn/2019/06/23/AM335X%E2%80%94%E2%80%94USB%E6%91%84%E5%83%8F%E5%A4%B4/#3-Web%E6%98%BE%E7%A4%BA ==执行mjpg_streamer获取摄像头数据== :如下所示我们使用-i参数指定输入so插件类型为uvc类型,-d参数指定使用的摄像头设备为/dev/video1 ,-r参数指定输入分辨率为640x480 ,-q参数指定uvc数据质量为90,-n参数说明不要初始化Linux-UVC驱动程序的dynctrls,-o参数指定输出类型为http方式,-w指定网站目录为/usr/camera/web mjpg_streamer -i "/usr/lib/mjpg-streamer/input_uvc.so -d /dev/video1 -r 640x480 -f 30 -q 90 -n" -o "/usr/lib/mjpg-streamer/output_http.so -w /usr/share/mjpg-streamer/www/" ==浏览器打开并查看摄像头数据== :如上所示我们的开发板IP地址为<code>192.168.1.21 </code>,让后我们使用电脑浏览器打开如下地址即可预览摄像头数据。 192.168.1.21:8080
Mjpg-streamer
