查看“Mjpg-streamer”的源代码
Mjpg-streamer
=查看摄像头数据= ==列出所有摄像头设备== :使用<code>v4l2-ctl --list-devices</code>命令来获取当前开发板下都有哪些摄像头设备,以及设备节点名称,如下所示我们使用的是USB摄像头对应的设备节点为<code> /dev/video1</code> <syntaxhighlight lang="bash"> [root@imx6ull:~]# v4l2-ctl --list-devices pxp (pxp_v4l2): /dev/video0 USB 2.0 Camera (usb-ci_hdrc.1-1.3): /dev/video1 </syntaxhighlight> ==查看摄像头详细信息== <syntaxhighlight lang="bash"> [root@imx6ull:~]# v4l2-ctl -L -d /dev/video1 brightness 0x00980900 (int) : min=-255 max=255 step=1 default=0 value=0 contrast 0x00980901 (int) : min=0 max=30 step=1 default=15 value=15 saturation 0x00980902 (int) : min=0 max=127 step=1 default=30 value=30 hue 0x00980903 (int) : min=-16000 max=16000 step=100 default=0 value=0 white_balance_temperature_auto 0x0098090c (bool) : default=1 value=1 gamma 0x00980910 (int) : min=20 max=250 step=1 default=98 value=98 power_line_frequency 0x00980918 (menu) : min=0 max=2 default=1 value=1 0: Disabled 1: 50 Hz 2: 60 Hz white_balance_temperature 0x0098091a (int) : min=2500 max=7000 step=1 default=5000 value=5000 flags=inactive sharpness 0x0098091b (int) : min=0 max=15 step=1 default=2 value=2 backlight_compensation 0x0098091c (int) : min=0 max=2 step=1 default=1 value=1 </syntaxhighlight> ==查看摄像头支持的像素格式和分辨率== <syntaxhighlight lang="bash"> [root@imx6ull:~]# v4l2-ctl --list-formats-ext -d /dev/video1 ioctl: VIDIOC_ENUM_FMT Type: Video Capture [0]: 'YUYV' (YUYV 4:2:2) Size: Discrete 640x480 Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.050s (20.000 fps) Interval: Discrete 0.067s (15.000 fps) Interval: Discrete 0.100s (10.000 fps) Interval: Discrete 0.200s (5.000 fps) Size: Discrete 160x120 Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.050s (20.000 fps) Interval: Discrete 0.067s (15.000 fps) Interval: Discrete 0.100s (10.000 fps) Interval: Discrete 0.200s (5.000 fps) Size: Discrete 320x240 Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.050s (20.000 fps) Interval: Discrete 0.067s (15.000 fps) Interval: Discrete 0.100s (10.000 fps) Interval: Discrete 0.200s (5.000 fps) Size: Discrete 352x288 Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.050s (20.000 fps) Interval: Discrete 0.067s (15.000 fps) Interval: Discrete 0.100s (10.000 fps) Interval: Discrete 0.200s (5.000 fps) Size: Discrete 800x600 Interval: Discrete 0.067s (15.000 fps) Interval: Discrete 0.100s (10.000 fps) Interval: Discrete 0.200s (5.000 fps) Size: Discrete 1280x720 Interval: Discrete 0.067s (15.000 fps) Interval: Discrete 0.100s (10.000 fps) Interval: Discrete 0.200s (5.000 fps) Size: Discrete 1280x1024 Interval: Discrete 0.083s (12.000 fps) Interval: Discrete 0.100s (10.000 fps) Interval: Discrete 0.200s (5.000 fps) Size: Discrete 1600x1200 Interval: Discrete 0.111s (9.000 fps) Interval: Discrete 0.200s (5.000 fps) [1]: 'MJPG' (Motion-JPEG, compressed) Size: Discrete 640x480 Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.050s (20.000 fps) Interval: Discrete 0.067s (15.000 fps) Interval: Discrete 0.100s (10.000 fps) Interval: Discrete 0.200s (5.000 fps) Size: Discrete 160x120 Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.050s (20.000 fps) Interval: Discrete 0.067s (15.000 fps) Interval: Discrete 0.100s (10.000 fps) Interval: Discrete 0.200s (5.000 fps) Size: Discrete 320x240 Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.050s (20.000 fps) Interval: Discrete 0.067s (15.000 fps) Interval: Discrete 0.100s (10.000 fps) Interval: Discrete 0.200s (5.000 fps) Size: Discrete 352x288 Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.050s (20.000 fps) Interval: Discrete 0.067s (15.000 fps) Interval: Discrete 0.100s (10.000 fps) Interval: Discrete 0.200s (5.000 fps) Size: Discrete 800x600 Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.050s (20.000 fps) Interval: Discrete 0.067s (15.000 fps) Interval: Discrete 0.100s (10.000 fps) Interval: Discrete 0.200s (5.000 fps) Size: Discrete 1280x720 Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.050s (20.000 fps) Interval: Discrete 0.067s (15.000 fps) Interval: Discrete 0.100s (10.000 fps) Interval: Discrete 0.200s (5.000 fps) Size: Discrete 1280x1024 Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.050s (20.000 fps) Interval: Discrete 0.067s (15.000 fps) Interval: Discrete 0.100s (10.000 fps) Interval: Discrete 0.200s (5.000 fps) </syntaxhighlight> =使用mjpg_streamer预览摄像头数据= ==查看开发板IP地址== <syntaxhighlight lang="bash"> [root@imx6ull:~]# ifconfig eth0 Link encap:Ethernet HWaddr 00:01:3F:2D:3E:4D UP BROADCAST MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) eth1 Link encap:Ethernet HWaddr 00:01:1F:2D:3E:4D inet addr:192.168.1.21 Bcast:192.168.1.255 Mask:255.255.255.0 inet6 addr: fdfd:3597:aa7a:0:201:1fff:fe2d:3e4d/64 Scope:Global inet6 addr: fe80::201:1fff:fe2d:3e4d/64 Scope:Link inet6 addr: fdfd:3597:aa7a::914/64 Scope:Global UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:558 errors:0 dropped:0 overruns:0 frame:0 TX packets:291 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:221870 (216.6 KiB) TX bytes:29419 (28.7 KiB) lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 inet6 addr: ::1/128 Scope:Host UP LOOPBACK RUNNING MTU:65536 Metric:1 RX packets:7756 errors:0 dropped:0 overruns:0 frame:0 TX packets:7756 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1 RX bytes:468263 (457.2 KiB) TX bytes:468263 (457.2 KiB) </syntaxhighlight> ==mjpg_streamer参数讲解== :使用mjpg_streamer -h 查看帮助信息。 <syntaxhighlight lang="bash"> [root@imx6ull:~]# mjpg_streamer -h ----------------------------------------------------------------------- Usage: mjpg_streamer -i | --input "<input-plugin.so> [parameters]" -o | --output "<output-plugin.so> [parameters]" [-h | --help ]........: display this help [-v | --version ].....: display version information [-b | --background]...: fork to the background, daemon mode ----------------------------------------------------------------------- Example #1: To open an UVC webcam "/dev/video1" and stream it via HTTP: mjpg_streamer -i "input_uvc.so -d /dev/video1" -o "output_http.so" ----------------------------------------------------------------------- Example #2: To open an UVC webcam and stream via HTTP port 8090: mjpg_streamer -i "input_uvc.so" -o "output_http.so -p 8090" ----------------------------------------------------------------------- Example #3: To get help for a certain input plugin: mjpg_streamer -i "input_uvc.so --help" ----------------------------------------------------------------------- In case the modules (=plugins) can not be found: * Set the default search path for the modules with: export LD_LIBRARY_PATH=/path/to/plugins, * or put the plugins into the "/lib/" or "/usr/lib" folder, * or instead of just providing the plugin file name, use a complete path and filename: mjpg_streamer -i "/path/to/modules/input_uvc.so" ----------------------------------------------------------------------- </syntaxhighlight> :得知mjpg_streamer后需要接-i和-o两个参数,再分别看这两个参数提供的不同so插件文件支持哪些选项。 :可选的-h查询帮助信息、-v查询版本信息、-b后台执行就不多介绍了。 :输入so插件包含:input_uvc.so、input_testpicture.so、(input_file.so、input_ptp2.so、input_http.so) :输出so插件包含:output_http.so、(output_file.so、output_udp.so、output_rtsp.so、output_viewer.so) :其中括号部分,我这个Buildroot的mjpg_streamer版本没有提供。 === 输入插件1:input_uvc.so=== <syntaxhighlight lang="bash"> # mjpg_streamer -i "/usr/lib/input_uvc.so --help" MJPG Streamer Version: git rev: fd184d0 --------------------------------------------------------------- Help for input plugin..: UVC webcam grabber --------------------------------------------------------------- The following parameters can be passed to this plugin: [-d | --device ].......: video device to open (your camera) [-r | --resolution ]...: the resolution of the video device, can be one of the following strings: QQVGA QCIF CGA QVGA CIF PAL VGA SVGA XGA HD SXGA UXGA FHD or a custom value like the following example: 640x480 [-f | --fps ]..........: frames per second (activates YUYV format, disables MJPEG) [-q | --quality ] .....: set quality of JPEG encoding [-m | --minimum_size ].: drop frames smaller then this limit, useful if the webcam produces small-sized garbage frames may happen under low light conditions [-e | --every_frame ]..: drop all frames except numbered [-n | --no_dynctrl ]...: do not initalize dynctrls of Linux-UVC driver [-l | --led ]..........: switch the LED "on", "off", let it "blink" or leave it up to the driver using the value "auto" [-t | --tvnorm ] ......: set TV-Norm pal, ntsc or secam [-u | --uyvy ] ........: Use UYVY format, default: MJPEG (uses more cpu power) [-y | --yuv ] ........: Use YUV format, default: MJPEG (uses more cpu power) [-fourcc ] ............: Use FOURCC codec 'argopt', currently supported codecs are: RGBP --------------------------------------------------------------- Optional parameters (may not be supported by all cameras): [-br ].................: Set image brightness (auto or integer) [-co ].................: Set image contrast (integer) [-sh ].................: Set image sharpness (integer) [-sa ].................: Set image saturation (integer) [-cb ].................: Set color balance (auto or integer) [-wb ].................: Set white balance (auto or integer) [-ex ].................: Set exposure (auto, shutter-priority, aperature-priority, or integer) [-bk ].................: Set backlight compensation (integer) [-rot ]................: Set image rotation (0-359) [-hf ].................: Set horizontal flip (true/false) [-vf ].................: Set vertical flip (true/false) [-pl ].................: Set power line filter (disabled, 50hz, 60hz, auto) [-gain ]...............: Set gain (auto or integer) [-cagc ]...............: Set chroma gain control (auto or integer) --------------------------------------------------------------- input_init() return value signals to exit </syntaxhighlight> *基本参数: :* -d:指定video设备节点 :* -r:指定分辨率,VGA或640x480类似值 :* -f:指定每秒帧数 :* -q:指定JPEG编码质量 :* -m:指定丢弃小于该值的帧 :* -e:删除除编号以外的所有帧 :* -n:不要初始化Linux-UVC驱动程序的dynctrls :* -l:设置LED on/off/blink,设置auto将取决于驱动程序 :* -t:设置TV-Norm pal,ntsc或secam :* -u:指定输入为UYVY格式,通过CPU将UYVC转为MJPEG,这样会消耗更多CPU :* -y:指定输入为YUV格式,通过CPU将YUV转为MJPEG,这样会消耗更多CPU :* -fourcc:使用FOURCC编解码器argopt,目前支持的编解码器是:RGBP :* 新版新增: :* -timestamp:使用系统时间填充帧时间戳 :* -softfps:丢帧以尝试实现此FPS *图像参数: :*-br:设置图像亮度 :*-co:设置图像对比度 :*-sh:设置图像清晰度 :*-sa:设置图像饱和度 :*-cb:设置图像颜色平衡 :*-wb:设置图像白平衡 :*-ex:设置图像曝光 :*-bk:设置图像曝光补偿 :*-rot:设置图像旋转0-359 :*-hf:设置图像水平翻转 :*-vf:设置图像垂直翻转 :*-pl:设置图像避免闪烁频率 :*-gain:设置图像增益 :*-cagc:设置图像色度增益控制 ===输入插件2:input_testpicture.so=== <syntaxhighlight lang="bash"> # mjpg_streamer -i "/usr/lib/input_testpicture.so --help" MJPG Streamer Version: git rev: fd184d0 --------------------------------------------------------------- Help for input plugin..: TESTPICTURE input plugin --------------------------------------------------------------- The following parameters can be passed to this plugin: [-d | --delay ]........: delay to pause between frames [-r | --resolution]....: can be 960x720, 640x480, 320x240, 160x120 --------------------------------------------------------------- input_init() return value signals to exit </syntaxhighlight> *基本参数: :*-d:指定在两帧之间的延时 :*-r:指定在分辨率 ===输入插件3:input_file.so=== <syntaxhighlight lang="bash"> # mjpg-streamer -i "/snap/mjpg-streamer/42/lib/mjpg-streamer/input_file.so --help" MJPG Streamer Version: git rev: f387bb44e6c087271b763b27da998bf2e06c4f5d --------------------------------------------------------------- Help for input plugin..: FILE input plugin --------------------------------------------------------------- The following parameters can be passed to this plugin: [-d | --delay ]........: delay (in seconds) to pause between frames [-f | --folder ].......: folder to watch for new JPEG files [-r | --remove ].......: remove/delete JPEG file after reading [-n | --name ].........: ignore changes unless filename matches [-e | --existing ].....: serve the existing *.jpg files from the specified directory --------------------------------------------------------------- input_init() return value signals to exit </syntaxhighlight> *基本参数: :*-d:指定在两帧之间的延时(单位:s) :*-f:指定查看新JEPG文件的目录 :*-r:指定读取后要删除的JEPG文件 :*-n:指定除非文件名匹配忽略更改 :*-e:指定目录读取现有JPG文件 ===输入插件4:input_ptp2.so=== <syntaxhighlight lang="bash"> # mjpg-streamer -i "/snap/mjpg-streamer/42/lib/mjpg-streamer/input_ptp2.so --help" MJPG Streamer Version: git rev: f387bb44e6c087271b763b27da998bf2e06c4f5d PTP2 input plugin: invalid option -- '-' --------------------------------------------------------------- Help for input plugin..: PTP2 input plugin --------------------------------------------------------------- The following parameters can be passed to this plugin: [-h ]..........: print this help [-u X ]........: delay between frames in us (default 0) [-d X ]........: camera address in [usb:xxx,yyy] form; use gphoto2 --auto-detect to get a list of available cameras --------------------------------------------------------------- input_init() return value signals to exit </syntaxhighlight> *基本参数: :*-h:打印帮助 :*-u:指定在两帧之间的延时(单位:us) :*-d:指定可用相机 ===输入插件5:input_http.so=== <syntaxhighlight lang="bash"> # mjpg-streamer -i "/snap/mjpg-streamer/42/lib/mjpg-streamer/input_http.so --help"" MJPG Streamer Version: git rev: f387bb44e6c087271b763b27da998bf2e06c4f5d --------------------------------------------------------------- Help for input plugin..: HTTP Input plugin --------------------------------------------------------------- The following parameters can be passed to this plugin: [-v | --version ]........: current SVN Revision [-h | --help]............: show this message [-H | --host]............: select host to data from, localhost is default [-p | --port]............: port, defaults to 8080 --------------------------------------------------------------- input_init() return value signals to exit </syntaxhighlight> *基本参数: :*-v:打印版本信息 :*-h:打印帮助信息 :*-H:指定主机地址 :*-p:指定端口 ===输出插件1:output_http.so=== <syntaxhighlight lang="bash"> # mjpg_streamer -o "/usr/lib/output_http.so --help" MJPG Streamer Version: git rev: fd184d0 --------------------------------------------------------------- Help for output plugin..: HTTP output plugin --------------------------------------------------------------- The following parameters can be passed to this plugin: [-w | --www ]...........: folder that contains webpages in flat hierarchy (no subfolders) [-p | --port ]..........: TCP port for this HTTP server [-l ] --listen ]........: Listen on Hostname / IP [-c | --credentials ]...: ask for "username:password" on connect [-n | --nocommands ]....: disable execution of commands --------------------------------------------------------------- output_init() return value signals to exit </syntaxhighlight> *基本参数: :*-w:指定网页根目录(不支持子文件夹) :*-p:指定HTTP服务器的TCP端口 :*-l:指定监听主机IP :*-c:指定在连接时询问的账户名、密码 :*-n:指定禁用命令执行 ===输出插件2:output_file.so=== <syntaxhighlight lang="bash"> # mjpg-streamer -o "/snap/mjpg-streamer/42/lib/mjpg-streamer/output_file.so --help" MJPG Streamer Version: git rev: f387bb44e6c087271b763b27da998bf2e06c4f5d --------------------------------------------------------------- Help for output plugin..: FILE output plugin --------------------------------------------------------------- The following parameters can be passed to this plugin: [-f | --folder ]........: folder to save pictures [-m | --mjpeg ].........: save the frames to an mjpg file [-l | --link ]..........: link the last picture in ringbuffer as this fixed named file [-d | --delay ].........: delay after saving pictures in ms [-i | --input ].........: read frames from the specified input plugin The following arguments are takes effect only if the current mode is not MJPG [-s | --size ]..........: size of ring buffer (max number of pictures to hold) [-e | --exceed ]........: allow ringbuffer to exceed limit by this amount [-c | --command ].......: execute command after saving picture --------------------------------------------------------------- output_init() return value signals to exit </syntaxhighlight> *基本参数: :*-f:指定保存图片文件夹 :*-m:将帧保存的mjpg文件夹 :*-l:将ringbuffer中的最后一张图片链接为此固定命名文件 :*-d:保存图片后延时(单位:ms) :*-i:从指定的输入插件中读取帧 *仅当当前模式不是MJPG时,以下参数才会生效 :*-s:环形缓冲区的大小(要保留的最大图片数) :*-e:允许ringbuffer超过此数量的限制 :*-c:保存图片后执行命令 ===输出插件3:output_udp.so=== <syntaxhighlight lang="bash"> # mjpg-streamer -o "/snap/mjpg-streamer/42/lib/mjpg-streamer/output_udp.so --help" MJPG Streamer Version: git rev: f387bb44e6c087271b763b27da998bf2e06c4f5d --------------------------------------------------------------- Help for output plugin..: UDP output plugin --------------------------------------------------------------- The following parameters can be passed to this plugin: [-f | --folder ]........: folder to save pictures [-d | --delay ].........: delay after saving pictures in ms [-c | --command ].......: execute command after saveing picture [-p | --port ]..........: UDP port to listen for picture requests. UDP message is the filename to save [-i | --input ].......: read frames from the specified input plugin (first input plugin between the arguments is the 0th) --------------------------------------------------------------- output_init() return value signals to exit </syntaxhighlight> *基本参数: :*-f:指定保存图片的文件夹 :*-d:保存图片后延时(单位:ms) :*-c:保存图片后执行命令 :*-p:指定UDP端口监听图片请求 :*-i:从指定的输入插件读取帧 ===输出插件4:output_rtsp.so=== <syntaxhighlight lang="bash"> # mjpg-streamer -o "/snap/mjpg-streamer/42/lib/mjpg-streamer/output_rtsp.so --help" MJPG Streamer Version: git rev: f387bb44e6c087271b763b27da998bf2e06c4f5d --------------------------------------------------------------- Help for output plugin..: RTSP output plugin --------------------------------------------------------------- The following parameters can be passed to this plugin: [-p | --port ]..........: UDP port to listen for picture requests. UDP message is the filename to save [-i | --input ].......: read frames from the specified input plugin (first input plugin between the arguments is the 0th) --------------------------------------------------------------- output_init() return value signals to exit </syntaxhighlight> *基本参数: :*-p:指定UDP端口监听图片请求 :*-i:从指定的输入插件读取帧 ===输出插件5:output_viewer.so=== <syntaxhighlight lang="bash"> # mjpg-streamer -o "/snap/mjpg-streamer/42/lib/mjpg-streamer/output_viewer.so --help" MJPG Streamer Version: git rev: f387bb44e6c087271b763b27da998bf2e06c4f5d --------------------------------------------------------------- Help for output plugin..: VIEWER output plugin --------------------------------------------------------------- output_init() return value signals to exit </syntaxhighlight> *基本参数: :*无 *参考页面 https://hceng.cn/2019/06/23/AM335X%E2%80%94%E2%80%94USB%E6%91%84%E5%83%8F%E5%A4%B4/#3-Web%E6%98%BE%E7%A4%BA ==执行mjpg_streamer获取摄像头数据== :如下所示我们使用-i参数指定输入so插件类型为uvc类型,-d参数指定使用的摄像头设备为/dev/video1 ,-r参数指定输入分辨率为640x480 ,-q参数指定uvc数据质量为90,-n参数说明不要初始化Linux-UVC驱动程序的dynctrls,-o参数指定输出类型为http方式,-w指定网站目录为/usr/camera/web mjpg_streamer -i "/usr/lib/mjpg-streamer/input_uvc.so -d /dev/video1 -r 640x480 -f 30 -q 90 -n" -o "/usr/lib/mjpg-streamer/output_http.so -w /usr/share/mjpg-streamer/www/" ==浏览器打开并查看摄像头数据== :如上所示我们的开发板IP地址为<code>192.168.1.21 </code>,让后我们使用电脑浏览器打开如下地址即可预览摄像头数据。 192.168.1.21:8080
Mjpg-streamer
