查看“AllCategories”的源代码
所有类别
{{DISPLAYTITLE:所有类别}} =开发环境相关= {|width="100%" style="text-align:left; background-color: rgba(255,255,255,0.2)" |- valign="top" | width="33%" | || || |} =Bootloard= {|width="100%" style="text-align:left; background-color: rgba(255,255,255,0.2)" |- valign="top" | width="33%" | *[[How_to_boot_the_kernel_via_TFTP_from_U-Boot]] *[[How_to_update_U-Boot_on_an_SD_card]] *[[How_to_use_USB_mass_storage_in_U-Boot]] *[[UBoot]] *[[UBootCmdFDT]] *[[UBootCmdGroupDownload]] *[[UBootCmdGroupEnvironment]] *[[UBootCmdGroupExec]] *[[UBootCmdGroupFlash]] *[[UBootCmdGroupInfo]] *[[UBootCmdGroupMemory]] *[[UBootCmdGroupMisc]] *[[UBootCmdGroupSpecial]] *[[UBootManual]] *[[UBootStorageDevices]] || || |} =Linux内核相关= ==内核驱动相关== {|width="100%" style="text-align:left; background-color: rgba(255,255,255,0.2)" ! 高速通信设备 !! 低速通信设备 !! 网络子系统 |- valign="top" | width="33%" | *alsa声卡相关 :*[[ALSA_overview | linux alsa声卡概述]] :*[[ALSA_troubleshooting_grid | linux alsa声卡故障排除]] :*[[How_to_play_audio | 如何播放音频]] :*[[How_to_record_audio | 如何录音]] :*[[I2S_device_tree_configuration | I2S协议如何配置设备树]] :*[[I2S_Linux_driver | I2S协议linux驱动]] :*[[SAI_device_tree_configuration | SAI协议设备树配置]] :*[[SAI_Linux_driver | SAI协议Linux驱动]] :*[[Soundcard_configuration | 声卡配置]] :*[[SPDIFRX_device_tree_configuration | SPDIFRX协议设备树配置]] :*[[SPDIFRX_Linux_driver | SPDIFRX协议Linux驱动]] :*[[Audio_troubleshooting_grid | 音频故障排除]] :*[[PulseAudio | PulseAudio工具]] *USB设备相关 :*[[USB overview | USB 概述 ]] :*[[PHY overview | USB PHY 层架构概述 ]] :*[[USBH device tree configuration | USB设备树配置 ]] :*[[USBPHYC device tree configuration | USB PHY层设备树配置]] :*[[OTG device tree configuration | USB OTG 设备树配置]] | width="33%" | *CAN协议相关 :*[[CAN overview | CAN协议概述]] :*[[FDCAN device tree configuration|CAN设备树配置]] :*[[How_to_set_up_a_SocketCAN_interface|如何设置CAN套接字接口]] :*[[How to send or receive CAN data |如何发送或接收CAN数据]] *串口设备相关 :*[[ How to use TTY from an application | 如何通过app使用TTY]] :*[[How to use TTY with User Terminal | 如何在用户终端下使用TTY]] :*[[Serial TTY device tree configuration | 串行TTY设备树配置]] :*[[Serial TTY line discipline | 串行TTY线路描述]] :*[[Serial TTY overview | TTY 架构概述]] :*[[TTY tools | TTY调试工具]] *SPI设备相关 :*[[SPI overview | SPI架构概述 ]] :*[[SPI device tree configuration | SPI设备树配置]] :*[[How to use SPI | 如何使用SPI]] *I2C设备相关 :*[[I2C overview | I2C协议概述]] :*[[I2C i2c-dev | I2C设备 ]] :*[[I2C device tree configuration | I2C设备树配置]] :*[[I2C driver | I2C驱动]] :*[[I2C i2c-tools | I2C测试工具]] | width="33%" | *蓝牙相关 :*[[Bluetooth overview | 蓝牙概述 ]] :*[[Bluetooth device tree configuration | 蓝牙设备树配置]] :*[[How to scan BLE devices | 如何扫描低功耗蓝牙设备]] :*[[How to scan Bluetooth devices | 如何扫描标准蓝牙设备]] :*[[How to set up a Bluetooth connection |如何设置蓝牙设备连接]] *WIFI设备相关 :*[[WLAN overview|WIFI概述]] :*[[WLAN device tree configuration|WIFI设备树配置]] :*[[How to configure a wlan interface on client mode | 如何配置waln设备客户端模式]] :*[[How to configure a wlan interface on hotspot mode|如何配置wlan设备热点模式]] :*[[How to setup wifi connection|如何设置WiFi连接]] *以太网相关 :*[[Ethernet overview | 以太网概述 ]] :*[[How to configure ethernet interface | 如何配置以太网接口]] :*[[Ethernet device tree configuration | 网络设备树配置]] *网络测试 :*[[How to perform ping test | 如何执行ping测试]] :*[[How to perform ssh connection | 如何执行SSH连接]] :*[[Network tools | 网络工具]] :*[[Networking overview |网络概述]] :*[[Networking troubleshooting grid|网络故障排除]] |} ==内核调试相关== {|width="100%" style="text-align:left; background-color: rgba(255,255,255,0.2)" |- valign="top" | width="33%" | *[[Blktrace]] *[[Dmesg and Linux kernel log]] *[[Ftrace]] *[[Ltrace]] *[[LTTng]] *[[Strace]] *[[Trace-cmd and kernelshark trace viewer]] | width="33%" | *[[Debugfs]] *[[Ethtool]] *[[Ifconfig]] *[[IP Linux command line]] *[[Kmemleak]] *[[Netdata]] *[[Netstat]] *[[Perf]] | width="33%" | *[[Pseudo filesystem]] *[[Sysdig]] *[[Sysprof]] *[[Sysstat tool suite]] *[[Systemtap]] *[[Tcpdump]] *[[Top Linux command line ]] *[[Valgrind]] |} =文件系统相关= {|width="100%" style="text-align:left; background-color: rgba(255,255,255,0.2)" |- valign="top" | width="33%" | *[[Adding_packages_to_your_OS_image]] *[[Adding_yocto_packages]] *[[How_to_accelerate_JPEG_compression_and_decompression]] *[[How_to_access_information_in_sysfs]] *[[How_to_activate_HSI_and_CSI_oscillators_calibration]] *[[How_to_activate_the_Gcnano_GPU_debug_mode]] *[[How_to_add_a_customer_application]] *[[How_to_add_a_new_package_to_buildroot]] *[[How_to_avoid_proxy_issues]] *[[How_to_boot_the_kernel_via_TFTP_from_U-Boot]] *[[How_to_build_Linux_kernel_user_space_tools]] *[[How_to_change_the_CPU_frequency]] *[[How_to_check_that_a_device_tree_resource_is_correctly_set]] *[[How_to_compile_the_device_tree_with_the_Developer_Package]] *[[How_to_compile_the_device_tree_with_the_Distribution_Package]] *[[How_to_config_the_git]] *[[How_to_configure_system_resources]] *[[How_to_configure_uniprocessor_mode]] *[[How_to_create_a_new_open_embedded_layer]] *[[How_to_create_an_SDK_for_OpenSTLinux_distribution]] *[[How_to_create_EXT4_images]] *[[How_to_create_ubi_images]] *[[How_to_create_your_board_device_tree]] |width="33%" | *[[How_to_create_your_own_distribution]] *[[How_to_create_your_own_image]] *[[How_to_create_your_own_machine]] *[[How_to_create_your_product_from_design_to_manufacturing]] *[[How_to_cross-compile_with_the_Developer_Package]] *[[How_to_cross-compile_with_the_Distribution_Package]] *[[How_to_customize_the_Linux_kernel]] *[[How_to_debug_a_Linux_kernel_crash]] *[[How_to_debug_the_Gcnano_GPU_with_VTK]] *[[How_to_detect_memory_leaks]] *[[How_to_diagnose_a_boot_failure]] *[[How_to_disable_one_CPU]] *[[How_to_enable_earlyprintk_for_Linux_kernel]] *[[How_to_enable_Jailhouse]] *[[How_to_enable_the_microphone_of_a_USB_camera]] *[[How_to_get_Terminal]] *[[How_to_install_JAVA_JDK]] *[[How_to_install_the_git]] *[[How_to_integrate_an_external_software_package]] *[[How_to_manage_the_debian_packages_in_OpenSTLinux_distribution]] *[[How_to_optimize_the_boot_time]] *[[How_to_play_a_video]] |width="33%" | *[[How_to_populate_and_boot_a_board_with_OP-TEE]] *[[How_to_populate_the_SD_card_with_dd_command]] *[[How_to_record_with_arecord]] *[[How_to_set_rtc_system_clock]] *[[How_to_setup_wifi_connection]] *[[How_to_submit_a_git_pull_request]] *[[How_to_transfer_a_file_over_network]] *[[How_to_transfer_a_file_over_serial_console]] *[[How_to_update_U-Boot_on_an_SD_card]] *[[How_to_use_samba]] *[[How_to_use_STM32CubeProgrammer_to_populate_a_board]] *[[How_to_use_the_git_branch_command]] *[[How_to_use_the_git_log_command]] *[[How_to_use_the_git_reset_command]] *[[How_to_use_the_rz_command_to_serially_transfer_files]] *[[How_to_use_USB_mass_storage_in_U-Boot]] *[[Menuconfig_or_how_to_configure_kernel]] *[[Play_audio]] *[[Yocto_build_system_FAQs]] |} ==buildroot相关== {|width="100%" style="text-align:left; background-color: rgba(255,255,255,0.2)" |- valign="top" | width="33%" | *[[Buildroot_Audio_and_video_applications]] *[[Buildroot_BuildOptions]] *[[Buildroot_Compressors_and_decompressors]] *[[Buildroot_Debugging_profiling_and_benchmark]] *[[Buildroot_Development_tools]] *[[Buildroot_Filesystem_and_flash_utilities]] *[[Buildroot_Fonts_cursors_icons_sounds_and_themes]] *[[Buildroot_Games]] *[[Buildroot_Graphic_libraries_and_applications]] *[[Buildroot_Hardware_handling]] *[[Buildroot_Interpreter_languages_and_scripting]] *[[Buildroot_Libraries]] *[[Buildroot_Mail]] *[[Buildroot_Miscellaneous]] *[[Buildroot_Networking_applications]] *[[Buildroot_Package_managers]] *[[Buildroot_Real-Time]] *[[Buildroot_Security]] *[[Buildroot_Shell_and_utilities]] *[[Buildroot_System_tools]] *[[Buildroot_SystemConfiguration]] *[[Buildroot_TargetOptions]] *[[Buildroot_Text_editors_and_viewers]] *[[Buildroot_Toolchain]] *[[How_to_add_a_new_package_to_buildroot]] || || |} ==yocto相关== {|width="100%" style="text-align:left; background-color: rgba(255,255,255,0.2)" |- valign="top" | width="33%" | *[[Adding_packages_to_your_OS_image]] *[[Adding_yocto_packages]] *[[Bitbake]] *[[How_to_create_your_own_image]] *[[How_to_create_your_own_machine]] *[[Yocto]] *[[Yocto_build_system_FAQs]] || || |} ==busybox相关== =应用相关=
所有类别
