查看“100ask stm32mp157 pro Kernel”的源代码
= Pinmux配置 = = dts层级结构 = = Audio类外设 = *[[ALSA_overview | linux alsa声卡概述]] *[[ALSA_troubleshooting_grid | linux alsa声卡故障排除]] *[[How_to_play_audio | 如何播放音频]] *[[How_to_record_audio | 如何录音]] *[[I2S_device_tree_configuration | I2S协议如何配置设备树]] *[[I2S_Linux_driver | I2S协议linux驱动]] *[[SAI_device_tree_configuration | SAI协议设备树配置]] *[[SAI_Linux_driver | SAI协议Linux驱动]] *[[Soundcard_configuration | 声卡配置]] *[[SPDIFRX_device_tree_configuration | SPDIFRX协议设备树配置]] *[[SPDIFRX_Linux_driver | SPDIFRX协议Linux驱动]] *[[Audio_troubleshooting_grid | 音频故障排除]] *[[PulseAudio | PulseAudio工具]] == WM8960芯片 == == SAI外设 == == SPDIFRX外设 == = GPIO LED驱动 = = GPIO按键驱动 = == GPIO矩阵键盘 == = Video类外设 = == DCMI外设 == == OV5640摄像头模组 == = 网络类外设 = *蓝牙相关 :*[[Bluetooth overview | 蓝牙概述 ]] :*[[Bluetooth device tree configuration | 蓝牙设备树配置]] :*[[How to scan BLE devices | 如何扫描低功耗蓝牙设备]] :*[[How to scan Bluetooth devices | 如何扫描标准蓝牙设备]] :*[[How to set up a Bluetooth connection |如何设置蓝牙设备连接]] *WIFI设备相关 :*[[WLAN overview|WIFI概述]] :*[[WLAN device tree configuration|WIFI设备树配置]] :*[[How to configure a wlan interface on client mode | 如何配置waln设备客户端模式]] :*[[How to configure a wlan interface on hotspot mode|如何配置wlan设备热点模式]] :*[[How to setup wifi connection|如何设置WiFi连接]] *以太网相关 :*[[Ethernet overview | 以太网概述 ]] :*[[How to configure ethernet interface | 如何配置以太网接口]] :*[[Ethernet device tree configuration | 网络设备树配置]] *网络测试 :*[[How to perform ping test | 如何执行ping测试]] :*[[How to perform ssh connection | 如何执行SSH连接]] :*[[Network tools | 网络工具]] :*[[Networking overview |网络概述]] :*[[Networking troubleshooting grid|网络故障排除]] == 4G模块驱动 == === EC20模块 === === ML302 === = FDCAN外设 = *CAN协议相关 :*[[CAN overview | CAN协议概述]] :*[[FDCAN device tree configuration|CAN设备树配置]] :*[[How_to_set_up_a_SocketCAN_interface|如何设置CAN套接字接口]] :*[[How to send or receive CAN data |如何发送或接收CAN数据]] == CM4配置 == = 低速接口类外设 = == I2C外设 == *[[I2C overview | I2C协议概述]] *[[I2C i2c-dev | I2C设备 ]] *[[I2C device tree configuration | I2C设备树配置]] *[[I2C driver | I2C驱动]] *[[I2C i2c-tools | I2C测试工具]] === CM4配置I2C === == SPI外设 == *[[SPI overview | SPI架构概述 ]] *[[SPI device tree configuration | SPI设备树配置]] *[[How to use SPI | 如何使用SPI]] === CA7配置SPI === === CM4使用SPI === === spidev驱动 === == 串口外设 == *串口设备相关 :*[[ How to use TTY from an application | 如何通过app使用TTY]] :*[[How to use TTY with User Terminal | 如何在用户终端下使用TTY]] :*[[Serial TTY device tree configuration | 串行TTY设备树配置]] :*[[Serial TTY line discipline | 串行TTY线路描述]] :*[[Serial TTY overview | TTY 架构概述]] :*[[TTY tools | TTY调试工具]] === CA7串口设备树配置 === === CM4配置串口 === = 模拟类外设 = == ADC外设 == *[[ADC_Linux_driver | ADC架构概述]] *[[ADC_device_tree_configuration | ADC设备树配置]] === CM4配置ADC === == DAC外设 == *[[DAC_Linux_driver | DAC架构概述]] *[[DAC_device_tree_configuration | DAC设备树树配置]] === CM4配置DAC === = DFSDM外设 = *[[DFSDM_Linux_driver | DFSDM架构概述]] *[[DFSDM_device_tree_configuration | DFDSM设备树配置]] = 显示类外设 = == LCD背光驱动 == == DSI外设 == === LTDC外设 === = 核心类外设 = == RTC驱动 == * [[RTC_overview | rtc架构概述]] * [[How_to_use_the_RTC | 如何使用rtc ]] * [[RTC_device_tree_configuration | RTC设备树配置]] * [[How_to_set_rtc_system_clock | 如何设置rtc系统时钟]] == TIM外设 == === CA7配置Capture功能 === === CM4使用Timer === === PWM输出配置 === == Watchdog外设 == === IWDG外设 === === WWDG外设 === == GPIO外设 == = 高速接口类外设 = == SDMMC外设 == * [[MMC_overview | MMC架构简介]] *[[SDMMC_device_tree_configuration | SDMMC设备设备树配置]] === CM4配置SDMMC3 === == USB设备驱动 == :*[[USB overview | USB 概述 ]] :*[[PHY overview | USB PHY 层架构概述 ]] :*[[USBH device tree configuration | USB设备树配置 ]] :*[[USBPHYC device tree configuration | USB PHY层设备树配置]] :*[[OTG device tree configuration | USB OTG 设备树配置]] == 存储类外设 == * [[MTD_overview | MTD架构概述]] * [[FMC_device_tree_configuration | FMC设备树配置]] === FMC外设 === === QUADSPI外设 === ==== CM4配置QSPI ==== == 安全类外设 == === CRC外设 === === CRYP外设 === === HASH外设 === === RNG外设 === =内核调试相关= {|width="100%" style="text-align:left; background-color: rgba(255,255,255,0.2)" |- valign="top" | width="33%" | *[[Blktrace]] *[[Dmesg and Linux kernel log]] *[[Ftrace]] *[[Ltrace]] *[[LTTng]] *[[Strace]] *[[Trace-cmd and kernelshark trace viewer]] | width="33%" | *[[Debugfs]] *[[Ethtool]] *[[Ifconfig]] *[[IP Linux command line]] *[[Kmemleak]] *[[Netdata]] *[[Netstat]] *[[Perf]] | width="33%" | *[[Pseudo filesystem]] *[[Sysdig]] *[[Sysprof]] *[[Sysstat tool suite]] *[[Systemtap]] *[[Tcpdump]] *[[Top Linux command line ]] *[[Valgrind]] |}
