查看“Network tools”的源代码
Network tools
== ping == 手册页位于 [http://man7.org/linux/man-pages/man8/ping.8.html ping(8)]<br /> '''ping''' 使用ICMP协议的强制性ECHO_REQUEST数据报来从主机或网关引出ICMP ECHO_RESPONSE。ECHO_REQUEST数据报具有IP和ICMP标头,后跟一个struct timeval,然后是任意数量的“ pad”字节,用于填充数据包。 == ifconfig == 请参考专用页面 [[Ifconfig|ifconfig]] == route == 手册页位于 [http://man7.org/linux/man-pages/man8/route.8.html route(8)]<br /> '''route''' 命令用于显示/操作IP路由表。 它主要用于设置通过接口到特定主机或网络的静态路由。 == traceroute == Man page at [http://man7.org/linux/man-pages/man8/traceroute.8.html traceroute(8)]<br /> '''traceroute''' is a built-in tool for displaying the route and measuring the delay of packets across a network. == netstat == Please refer to the dedicated page [[Netstat|netstat]] == ip == Please refer to the dedicated page [[IP Linux command line|ip]] == ethtool == Man page at [http://man7.org/linux/man-pages/man8/ethtool.8.html ethtool(8)]<br /> '''ethtool''' utility is used to view and change the ethernet device parameters. == iw == Man page at [http://linux.die.net/man/8/iw iw(8)]<br /> '''iw''' utility is used to view and change the wireless device parameters. == wpa_supplicant == Man page at [https://wiki.archlinux.org/index.php/WPA_supplicant wpa_supplicant]<br /> '''wpa_supplicant''' is a WPA Supplicant for Linux, BSD, Mac OS X, and Windows with support for WPA and WPA2 (IEEE 802.11i / RSN). It is suitable for both desktop/laptop computers and embedded systems. Supplicant is the IEEE 802.1X/WPA component that is used in the client stations. It implements key negotiation with a WPA Authenticator and it controls the roaming as well as IEEE 802.11 authentication/association of the wlan driver. == brctl == Man page at [http://linux.die.net/man/8/brctl brctl(8)]<br /> '''brctl''' is used to set up, maintain, and inspect the ethernet bridge configuration in the linux kernel. An ethernet bridge is a device commonly used to connect different physical Ethernet networks together, so that these physical networks appear as one unified network to the users. == iptables == Man page at [http://linux.die.net/man/8/iptables iptables(8)]<br /> '''iptables''' is an administration tool for IPv4 packet filtering and NAT.<br /> It is used to set up, maintain, and inspect the tables of IP packet filter rules in the Linux kernel. Several different tables may be defined. Each table contains a number of built-in chains and may also contain user-defined chains.<br /> Each chain is a list of rules which can match a set of packets. Each rule specifies what to do with a packet that matches. This is called a 'target', which may be a jump to a user-defined chain in the same table. == gatttool == Man page at [http://manpages.ubuntu.com/manpages/cosmic/man1/gatttool.1.html] <noinclude> [[Category:Netdev]] {{PublicationRequestId | 10432 | 2019-01-24 | BrunoB}} </noinclude>
Network tools
