查看“ADC Linux driver”的源代码
ADC Linux driver
== Article purpose == 本文介绍了用于ADC <ref name="ADC internal peripheral">[[ADC internal peripheral]]</ref>内部外围设备的Linux<sup>®</sup>驱动程序: * 驱动程序支持哪些ADC功能 * 如何配置,使用和调试驱动程序 * 驱动程序的结构是什么,以及在哪里可以找到源代码。 == Short description == ADC Linux<sup>®</sup>驱动程序(内核空间)基于 [[IIO overview|IIO]] 框架。 它支持两种模式: # '''IIO直接模式''':在通道上单次捕获(使用中断) # '''IIO触发缓冲模式''':在一个或多个通道上捕获(最好使用DMA)。<br/>它使用IIO中提供的硬件触发器。 请参阅[[TIM Linux driver]] and [[LPTIM Linux driver]]. == Configuration == === Kernel configuration === 使用Linux Menuconfig工具在内核配置中激活ADC <ref name="ADC internal peripheral"/> Linux<sup>®</sup> 驱动程序: [[Menuconfig or how to configure kernel]] (同时启用CONFIG_STM32_ADC_CORE和CONFIG_STM32_ADC). <pre> Device Drivers ---> <*> Industrial I/O support ---> Analog to digital converters ---> <*> STMicroelectronics STM32 adc core <*> STMicroelectronics STM32 adc </pre> === Device tree === 在配置ADC Linux内核驱动程序时,请参考[[ADC device tree configuration]] 文章。 == How to use == 在“'''IIO直接模式'''”中,可以直接从'''sysfs'''读取转换结果 (请参阅 [[How to use the IIO user space interface#How to do a simple ADC conversion using the sysfs interface|How to do a simple ADC conversion using the sysfs interface]]). 在“'''IIO触发缓冲区模式'''”中,必须先使用'''sysfs'''执行配置。 然后,使用“字符设备”(/ dev / iio:deviceX)读取数据 (请参阅[[How to use the IIO user space interface#Convert one or more channels using triggered buffer mode|Convert one or more channels using triggered buffer mode]]). == How to trace and debug == Refer to [[IIO_overview#How_to_trace_with_dynamic_debug|How to trace with dynamic debug]] for how to '''enable the debug logs''' in the driver and in the framework. Refer to [[IIO_overview#How_to_debug_with_debugfs|How to debug with debugfs]] for how to '''access the ADC registers'''. The ADC has system wide dependencies towards other key resources: * '''runtime power management''' can be disabled, for example it may be forced '''on''' via ''power/control'' sysfs entry: {{Board$}} cd /sys/devices/platform/soc/48003000.adc/48003000.adc:adc@0 {{Board$}} cat power/autosuspend_delay_ms 2000 {{Board$}} cat power/control auto # kernel is allowed to automatically suspend the ADC device after autosuspend_delay_ms {{Board$}} {{highlight|echo on > power/control}} # force the kernel to resume the ADC device (e.g. keep clocks and regulators enabled) {{Info| It might be useful to disable runtime power management, in order to dump registers by any means or to check clock and regulator usage (see example below).}} * '''clock'''<ref name="Clock overview">[[Clock overview]]</ref> usage can be verified by reading ''clk_summary'': {{Board$}} {{highlight|cat /sys/kernel/debug/clk/clk_summary}} | grep adc adc12_k 1 1 0 24000000 0 0 adc12 1 1 0 196607910 0 0 * '''regulator'''<ref name="Regulator overview">[[Regulator overview]]</ref> tree and usage can be verified (e.g. use count, open count or regulator reference voltage) as follows: {{Board$}} {{highlight|cat /sys/kernel/debug/regulator/regulator_summary}} regulator use open bypass voltage current min max ------------------------------------------------------------------------------- v3v3 4 5 0 3300mV 0mA 3300mV 3300mV vdda 1 2 0 2900mV 0mA 2900mV 2900mV 40017000.dac 0mV 0mV 48003000.adc 0mV 0mV * '''pinctrl'''<ref name="Pinctrl_overview">[[Pinctrl overview]]</ref> usage can be verified by reading ''pinmux-pins'': {{Board$}} cd /sys/kernel/debug/pinctrl/soc\:pin-controller@50002000/ {{Board$}} {{highlight|cat pinmux-pins}} | grep adc pin 92 (PF12): device 48003000.adc function {{highlight|analog}} group PF12 # check pin is assigned to ADC and is configured as "analog" * '''interrupts''' can be verified by reading "interrupts": {{Board$}} {{highlight|cat /proc/interrupts}} CPU0 CPU1 56: 2 0 dummy 0 Edge 48003000.adc:adc@0 == Source code location == The ADC source code is composed of: * {{CodeSource | Linux kernel | drivers/iio/adc/stm32-adc-core.c | stm32-adc-core driver}} to handle common resources such as clock (selection, prescaler), [[Regulator overview|regulator]] used as reference voltage, interrupt and common registers. * {{CodeSource | Linux kernel | drivers/iio/adc/stm32-adc.c | stm32-adc driver}} to handle the resources available for each ADC such as channel configuration and buffer handling. ==References== <references /> <noinclude> [[Category:IIO]] {{PublicationRequestId | 9337 | 2018-10-23 | AnneJ}} {{ArticleBasedOnModel | Linux driver article model}} </noinclude>
模板:Info
模板:STDarkBlue
ADC Linux driver
