查看“Vivante GCNANO GPU overview”的源代码
==Introduction== STMicroelectronics STM32MP1平台具有基于'''Vivante Gcnano GPU'''的'''OpenGLES'''硬件IP。.<br> 您可以在'''Vivante GCNANO网页'''上找到更多信息。<ref> http://www.vivantecorp.com/index.php/en/media-article/news/281-20140602-vivante-intros-worlds-first-complete-line-of-gpus-for-wearables-and-iot.html </ref> <ref> http://www.vivantecorp.com/index.php/en/technology/3d.html </ref> ==Features== ===Supported open standards=== '''Vivante Gcnano GPU''' 与以下'''Khronos的开放标准3D图形'''<ref> http://www.khronos.org/ </ref>: * OpenGLES 2.0 * OpenGLES 1.1 * OpenVG 1.1 * EGL 1.4 ===Vivante Gcnano GPU configuration=== * '''Core Clock''' 264MHz * '''Shader Clock''' 264MHz * '''Pixel Rate''' 264 MPixel/sec * '''Triangle Rate''' 26.4 M tri/sec * '''Vertex rate''' 66 M vtx/sec * '''1 shader core (Vec 4)''' * '''2.112 GFLOPS shader''' ==GPU softwares== [[File:GPU_software_structure.png|center|800px|link=]] ===Vivante Gcnano GPU userland libraries=== 除非客户与Vivante签署了保密协议(如果需要这些库源代码,请联系Vivante)。 Gcnano库(用户)是: * OpenGLES 1.1 library * OpenGLES 2.0 library * EGL 1.4 library * gbm library * GAL library * GLSLC and VSC libraries * VDK library ===Vivante Gcnano kernel driver=== '''{{Green|Source code is available for all customers}}''' in all OpenSTLinux baselines. <br> <br> To access source code: devtool modify gcnano-driver-stm32mp Source code is then downloaded here: *'''<your_view>/build*/workspace/sources/gcnano-driver-stm32mp''' <br> Refer to [[OpenEmbedded - devtool]] to know more about devtool. ===Additional information=== * STMicroelectronics provides '''debug Vivante Gcnano libraries''' according to any baseline version, '''allowing customers to debug/analyze their applications''' with the '''Vivante Tool Kit (VTK)'''. Please have a look to the article [[How to debug the Gcnano GPU with VTK]] for more details. ==Useful links== * Vivante website: http://www.vivantecorp.com/ ==EGL== ===Supported EGL backend=== From VIVANTE_GAL3D_Unified_Src_drv_6.1.x, Vivante delivery, Vivante Gcnano libraries support both '''DRM/GBM''' and '''Wayland''' backends.<br> Refer to [[EGL backends]] article for details. ===EGL texture 0-copy=== Gcnano supports the EGL texture 0-copy extension. EGL texture 0-copy extension allows an EGL application to share a texture buffer with the GPU by avoiding to copy the texture from application to the GPU. Refer to [[EGL texture 0-copy]] article for more details. ==Graphic Benchmarks== Please refer to the [[How to test and benchmark OpenGLES]] article. ==Debugging== Please have a look to following articles: * [[How to activate the Gcnano GPU debug mode]] * [[How to debug the Gcnano GPU with VTK]] ==References== <references /> <noinclude> [[Category:GPU]] </noinclude>
模板:Green
模板:STDarkGreen
